cubalibre
#1 Posted : Monday, October 17, 2011 10:08:56 AM(UTC)
cubalibre
I'm trying to stream 2 video sources using vmix basic, but I'm receiving the above error mentioned in the title of this thread, while trying to use one of the video sources.
This is a Sumikon helmet camera which comes with webcam drivers and I successfully can use with other software (live encoder, virtualdub). The drivers it uses are the SPCA1528 from Sunplus. I'm on XP pro.
Any help would be appreciated.
#2 Posted : Monday, October 17, 2011 9:38:30 PM(UTC)
The full error message lists what resolution you can select, it will be listed at the bottom of the error message.
cubalibre
#3 Posted : Monday, October 17, 2011 10:28:19 PM(UTC)
cubalibre
Hey Martin, thanks for your reply.
I should have mention that I did try different capture resolution settings, but the error is still there. Please notice that if I use those same resolutions (actually any resolution till 600x400) in adobe live encoder, the camera shows up just fine.
#4 Posted : Tuesday, October 18, 2011 12:20:02 AM(UTC)
Please try a couple of resolutions again and click Send Error Report so I can investigate further.
Most likely the camera does not support high frame rates which would make it unsuitable for use with vMix.
cubalibre
#5 Posted : Thursday, October 20, 2011 9:01:08 AM(UTC)
cubalibre
Hey Martin,
I sent you a couple of error reports. Can you confirm that the problem is in the camera's FPS?
Regards.
prabcharan
#6 Posted : Thursday, July 22, 2021 6:45:15 PM(UTC)
prabcharan
India
i am facing the problem saying Capture Device Is Not Supported, Device Reported the following: Output0
Please help me with any solution
#7 Posted : Friday, July 23, 2021 12:57:55 AM(UTC)
Why did you not post your problem as a new topic instead of adding it to a 10 year old one ? A lot has changed in this period of time!
Also in order for anyone to be able to help you will need to provide much more information : you hardware, version and license maybe even some screenshots. This forum is not intended to be a guessing game
Similar Topics
Capture Resolutioin is not Supported by this Device (General Discussion)
by meen1230 9/27/2015 11:34:37 AM(UTC)
