IOANNIS PANTSIOS
#1 Posted : Thursday, July 22, 2021 1:34:52 AM(UTC)
IOANNIS PANTSIOS
Greece
Hi there,
I am streaming for a basketball event and from time to time the audio seems to doubled. I do not use OBS or something, I do turn on and off my audio sources by shortcuts. Both times it happened in the beginning of the stream , the solution was to make a quick restart in vmix and start streaming again. Stopping and starting the stream or enabling and disabling the audio was not enough.
I am useing the latest version of Vmix.
BAD AUDIO STREAMING
Any ideas?
MartLeib
#2 Posted : Thursday, July 22, 2021 3:03:09 AM(UTC)
MartLeib
Estonia
Maybe you have live stream open in chrome/browser?
Check vMix audio setting that Headphones and Master are not sent to same device.
IOANNIS PANTSIOS
#3 Posted : Thursday, July 22, 2021 8:36:05 AM(UTC)
IOANNIS PANTSIOS
Greece
Hi MartLeib,
no I do not have a browser open, and the headphones output was disabled. Even if it wasn't, the fault seems to happen randomly during the production. We do 3 live stream per day for 3 days, but it happened only twice. I think this might be a bug, because both times it was fixed by restarting Vmix
