faulty audio while streaming
Hi there, I am streaming for a basketball event and from time to time the audio seems to doubled. I do not use OBS or something, I do turn on and off my audio sources by shortcuts. Both times it happened in the beginning of the stream , the solution was to make a quick restart in vmix and start streaming again. Stopping and starting the stream or enabling and disabling the audio was not enough. I am useing the latest version of Vmix. BAD AUDIO STREAMINGAny ideas?
Joined: 2/23/2017(UTC) Posts: 189  Thanks: 1 times Was thanked: 52 time(s) in 42 post(s)
Maybe you have live stream open in chrome/browser? Check vMix audio setting that Headphones and Master are not sent to same device.
Hi MartLeib,
no I do not have a browser open, and the headphones output was disabled. Even if it wasn't, the fault seems to happen randomly during the production. We do 3 live stream per day for 3 days, but it happened only twice. I think this might be a bug, because both times it was fixed by restarting Vmix
