merge transition problem with 1st input box
Joined: 4/27/2020(UTC) Posts: 5  Location: Tripura Thanks: 2 times
 20210621_164755.zip (3,763kb) downloaded 2 time(s).When I click merge transition for input one , its show me transparent for few second but during second input merge transition play ok .
Originally Posted by: bidyut   20210621_164755.zip (3,763kb) downloaded 2 time(s).When I click merge transition for input one , its show me transparent for few second but during second input merge transition play ok .
Joined: 12/27/2012(UTC) Posts: 5,515  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Is due to the layer position of each input , need to switch them before merging. For best effect merging works best between inputs containing the same layer content. BTW Still on Trial ????
Originally Posted by: doggy  Is due to the layer position of each input , need to switch them before merging. For best effect merging works best between inputs containing the same layer content. BTW Still on Trial ???? licence version is using in our office .I check with licence version and same problem .
Originally Posted by: bidyut  licence version is using in our office .I check with licence version and same problem .
Yeah right . you do know with a proper license the same can be used in the office and at home "problem" and solution mentioned, also watch the video for soulution
Problem solved. Thank you
