bidyut
#1 Posted : Monday, June 21, 2021 9:23:03 PM(UTC)
bidyut
India
20210621_164755.zip (3,763kb) downloaded 2 time(s).
When I click merge transition for input one , its show me transparent for few second but during second input merge transition play ok .
bidyut
#2 Posted : Monday, June 21, 2021 9:24:47 PM(UTC)
bidyut
India
#3 Posted : Monday, June 21, 2021 10:20:39 PM(UTC)
Is due to the layer position of each input , need to switch them before merging.
For best effect merging works best between inputs containing the same layer content.
BTW Still on Trial ????
bidyut on 6/22/2021(UTC)
bidyut
#4 Posted : Monday, June 21, 2021 10:36:54 PM(UTC)
bidyut
India
licence version is using in our office .I check with licence version and same problem .
#5 Posted : Tuesday, June 22, 2021 12:00:05 AM(UTC)
Yeah right . you do know with a proper license the same can be used in the office and at home
"problem" and solution mentioned, also watch the video for soulution
bidyut
#6 Posted : Tuesday, June 22, 2021 1:23:35 AM(UTC)
bidyut
India
Problem solved. Thank you
