GT
Resize Rectangle - Possible?
Joined: 3/26/2020(UTC) Posts: 23   Thanks: 4 times Was thanked: 3 time(s) in 3 post(s)
Is it possible to auto-resize a rectangle, based on the above text box width?
Lets say I have a lower third GT file that has simply a TextBlock1 above a Rectangle1. The Text is set to automatically resize Width. Is it possible to stretch the underlying Rectangle1 so that if there is a small amount of text, the rectangle would autosize and be narrower vs if there was a lot of text and the Rectangle gets wider automagically?
I know Expression has this functionality quite easily.
Thanks.
Joined: 12/27/2012(UTC) Posts: 5,483  Location: Belgium Thanks: 314 times Was thanked: 1018 time(s) in 836 post(s)
Originally Posted by: tcconway  Is it possible to auto-resize a rectangle, based on the above text box width . Yes
Is it possible to have two TextBlocks do this as well: For example TextBlock1 = "First Lastname" and TextBlock = "@twitterhandle" and have them "on the same line" so that if the name is long, it pushes the @twitterhandle to the right?
Thanks again!
Originally Posted by: tcconway  Is it possible to have two TextBlocks do this as well: For example TextBlock1 = "First Lastname" and TextBlock = "@twitterhandle" and have them "on the same line" so that if the name is long, it pushes the @twitterhandle to the right?
Thanks again! What have you tried ? Not with GT titles but with legacy XAML (WPF) titles you might
Joined: 2/18/2014(UTC) Posts: 1,845 Location: Stockholm
 1 user thanked richardgatarski for this useful post.
Is it possible to do this with right-aligned text? Whenever I set the textbox to "width", it then forces left-aligned text.
Originally Posted by: tcconway  Is it possible to do this with right-aligned text? Whenever I set the textbox to "width", it then forces left-aligned text. Answer included in your question => No
GT
