tcconway
#1 Posted : Sunday, May 16, 2021 5:21:52 AM(UTC)
tcconway
Is it possible to auto-resize a rectangle, based on the above text box width?
Lets say I have a lower third GT file that has simply a TextBlock1 above a Rectangle1. The Text is set to automatically resize Width. Is it possible to stretch the underlying Rectangle1 so that if there is a small amount of text, the rectangle would autosize and be narrower vs if there was a lot of text and the Rectangle gets wider automagically?
I know Expression has this functionality quite easily.
Thanks.
#2 Posted : Sunday, May 16, 2021 5:46:14 AM(UTC)
Yes
tcconway on 5/16/2021(UTC)
tcconway
#3 Posted : Sunday, May 16, 2021 7:34:11 AM(UTC)
tcconway
Is it possible to have two TextBlocks do this as well:
For example TextBlock1 = "First Lastname" and TextBlock = "@twitterhandle" and have them "on the same line" so that if the name is long, it pushes the @twitterhandle to the right?
Thanks again!
#4 Posted : Sunday, May 16, 2021 8:23:18 AM(UTC)
Thanks again!
What have you tried ?
Not with GT titles but with legacy XAML (WPF) titles you might
tcconway on 5/18/2021(UTC)
richardgatarski
#5 Posted : Sunday, May 16, 2021 4:42:51 PM(UTC)
richardgatarski
Rank:: Advanced Member
tcconway, If you want that feature in GT, consider voting for it at https://forums.vmix.com/...nd-following-text-length
tcconway
#6 Posted : Tuesday, May 18, 2021 11:24:51 PM(UTC)
tcconway
Is it possible to do this with right-aligned text? Whenever I set the textbox to "width", it then forces left-aligned text.
#7 Posted : Wednesday, May 19, 2021 12:46:06 AM(UTC)
Answer included in your question => No
