Papo
#1 Posted : Saturday, May 8, 2021 7:43:48 AM(UTC)
Papo
Peru
Greetings to all, I would like to know how to add values to a Dynamic that is to say that it starts with 1 but then according to the keystrokes it adds up to + 20 or + 8, I have been practicing the tutorials and the inputdynamic and setdynamicvalue everything ok but I would like the value of the text to be added but not + = 1 but according to the key pressed.
#2 Posted : Saturday, May 8, 2021 11:16:24 AM(UTC)
If you want to change Dynamic Values after some math you will need to use scripts (read value, add value write back result)
if it is to update existent values in a title you can have shortcuts (based on the key you use ) to just add the value : instead of +=1 can use +=(specific value)
Papo
#3 Posted : Saturday, May 8, 2021 1:52:29 PM(UTC)
Papo
Peru
Thanks for answering friend, well, it is to select a SelectedIndex for a SetVirtual, I have several zooms of different position so I would like to use the Dynamic to choose the indexes but according to the keys pressed, I do not know if it would be good to go that way
#4 Posted : Saturday, May 8, 2021 4:37:07 PM(UTC)
This becoming really confusing.
Initially you are asking about how to set Dynamic values , then regarding updating like a title text with a different value than +=1, and now regarding what i believe to be selecting and or changing sources in a virtual set and then a talk about various zooms (i think regarding the zoom presets of a virtual set)
Maybe it is just this that you want ?
https://www.vmix.com/kno...s-angles-using-shortcuts
Papo
#5 Posted : Sunday, May 9, 2021 4:45:50 AM(UTC)
Papo
Peru
I am very well on that path, excuse me friend for being confusing, excuse me, according to the link [https://www.vmix.com/kno...s-angles-using-shortcuts] to which point 5 speaks is what I mean, that value would be set by a Dynamic1 for example, and depending on the keys that you press change their values, I thought of adding +10 or +3 or +0 depending on the keystrokes; Well, in that Dynamic1 would be the value in point 5 of its link that gave me https://www.vmix.com/kno...-angles-using-shortcuts,
translated from google
