How you can add the value of a Dynamic
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
Greetings to all, I would like to know how to add values to a Dynamic that is to say that it starts with 1 but then according to the keystrokes it adds up to + 20 or + 8, I have been practicing the tutorials and the inputdynamic and setdynamicvalue everything ok but I would like the value of the text to be added but not + = 1 but according to the key pressed.
Originally Posted by: Papo  Greetings to all, I would like to know how to add values to a Dynamic that is to say that it starts with 1 but then according to the keystrokes it adds up to + 20 or + 8, I have been practicing the tutorials and the inputdynamic and setdynamicvalue everything ok but I would like the value of the text to be added but not + = 1 but according to the key pressed. If you want to change Dynamic Values after some math you will need to use scripts (read value, add value write back result) if it is to update existent values in a title you can have shortcuts (based on the key you use ) to just add the value : instead of +=1 can use +=(specific value)
Thanks for answering friend, well, it is to select a SelectedIndex for a SetVirtual, I have several zooms of different position so I would like to use the Dynamic to choose the indexes but according to the keys pressed, I do not know if it would be good to go that way
Originally Posted by: Papo  Thanks for answering friend, well, it is to select a SelectedIndex for a SetVirtual, I have several zooms of different position so I would like to use the Dynamic to choose the indexes but according to the keys pressed, I do not know if it would be good to go that way This becoming really confusing. Initially you are asking about how to set Dynamic values , then regarding updating like a title text with a different value than +=1, and now regarding what i believe to be selecting and or changing sources in a virtual set and then a talk about various zooms (i think regarding the zoom presets of a virtual set) Maybe it is just this that you want ? https://www.vmix.com/kno...s-angles-using-shortcuts
I am very well on that path, excuse me friend for being confusing, excuse me, according to the link [https://www.vmix.com/kno...s-angles-using-shortcuts] to which point 5 speaks is what I mean, that value would be set by a Dynamic1 for example, and depending on the keys that you press change their values, I thought of adding +10 or +3 or +0 depending on the keystrokes; Well, in that Dynamic1 would be the value in point 5 of its link that gave me https://www.vmix.com/kno...-angles-using-shortcuts,translated from google
