Dear Forum,
I'll need to configure PCs running VMIX Pro with 1x Decklink Quad 2 (8x SDI I/O, used as 4xInput/4xOutput).
I realized RTX 3080 cards are very hard to get in europe, currently with delivery time of weeks or even months.
Will I experience any considerable limitations using a Quadro RTX 4000 instead? (These are used in HP workstations that would be available immediately)
Another question: I suppose VMIX will run on AMD Threadripper platforms as well as with i9 CPUs. Is there any recommendation nevertheless?
Thank you Martin
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 87 time(s) in 67 post(s)
4 SDI IN and also 2 SDI OUT will work fine with a Quadro RTX 4000. vMix supports only 2 SDI out.
Joined: 2/4/2019(UTC) Posts: 3  Location: Adelaide Thanks: 2 times
Medialooks have some free apps that convert SDI to NDI and NDI to SDI which can help add the extra IO required to/from vMix. As far as using AMD processors vMix's recommendation is to use 3000 series (zen 2) or greater.
Joined: 2/1/2021(UTC) Posts: 11  Location: Milano Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: Peter1000  4 SDI IN and also 2 SDI OUT will work fine with a Quadro RTX 4000. vMix supports only 2 SDI out. Hi Peter1000, good to read about RTX4000. May I ask you the resolution of your vMix projects? Just to know how much harder is possible to use this GPU. many tnx. MrBossItaly.
