abalone76
#1 Posted : Tuesday, April 27, 2021 8:09:23 PM(UTC)
abalone76
Switzerland
Dear Forum,
I'll need to configure PCs running VMIX Pro with 1x Decklink Quad 2 (8x SDI I/O, used as 4xInput/4xOutput).
I realized RTX 3080 cards are very hard to get in europe, currently with delivery time of weeks or even months.
Will I experience any considerable limitations using a Quadro RTX 4000 instead? (These are used in HP workstations that would be available immediately)
Another question: I suppose VMIX will run on AMD Threadripper platforms as well as with i9 CPUs. Is there any recommendation nevertheless?
Thank you
Peter1000
#2 Posted : Tuesday, April 27, 2021 11:38:54 PM(UTC)
Peter1000
Switzerland
Was thanked: 87 time(s) in 67 post(s)
4 SDI IN and also 2 SDI OUT will work fine with a Quadro RTX 4000.
vMix supports only 2 SDI out.
schrojo
#3 Posted : Friday, April 30, 2021 8:29:57 PM(UTC)
schrojo
Medialooks have some free apps that convert SDI to NDI and NDI to SDI which can help add the extra IO required to/from vMix.
As far as using AMD processors vMix's recommendation is to use 3000 series (zen 2) or greater.
mrbossitaly
#4 Posted : Tuesday, May 11, 2021 9:56:55 PM(UTC)
mrbossitaly
Italy
Hi Peter1000,
good to read about RTX4000.
May I ask you the resolution of your vMix projects?
Just to know how much harder is possible to use this GPU.
many tnx.
MrBossItaly.
