Murchik
#1 Posted : Wednesday, April 7, 2021 9:56:28 PM(UTC)
Murchik
Ukraine
VRAM! video memory used incorrectly
in the latest updates there was an error with the use of video memory! Previously, it was enough for all projects with a margin, but now it is not enough in terms of vMix, while there is more than enough video memory in the system! At what stage did the failure occur and how to fix it ???
In the settings (after the initial ones) I did not change anything and there were no such problems before
https://youtu.be/MHV82P0XyJY
#2 Posted : Thursday, April 8, 2021 3:10:45 AM(UTC)
There have been no changes in this regard in vMix.
See below:
https://www.vmix.com/kno...n-in-the-vmix-status-bar
Any increase in the stats means you have changed something in the production, such as more inputs or higher resolution inputs.
Murchik
#3 Posted : Friday, April 9, 2021 1:51:41 AM(UTC)
Murchik
Ukraine
See below:
projects have been unchanged for over a year, and the indicator started lying after the appearance of version 24. If before that the difference in VRam load rates was 10-20%, now it does not correspond to reality at all. Moreover, if you still try to add something to the project, then the indicator shows 100% with overload!
