VRAM! video memory used incorrectly
Joined: 9/13/2016(UTC) Posts: 118   Location: Ukraine Thanks: 6 times Was thanked: 5 time(s) in 4 post(s)
VRAM! video memory used incorrectly in the latest updates there was an error with the use of video memory! Previously, it was enough for all projects with a margin, but now it is not enough in terms of vMix, while there is more than enough video memory in the system! At what stage did the failure occur and how to fix it ??? In the settings (after the initial ones) I did not change anything and there were no such problems before  Vram.PNG (61kb) downloaded 0 time(s).https://youtu.be/MHV82P0XyJY
Joined: 1/13/2010(UTC) Posts: 5,317  Location: Gold Coast, Australia Was thanked: 4718 time(s) in 1616 post(s)
Originally Posted by: admin  projects have been unchanged for over a year, and the indicator started lying after the appearance of version 24. If before that the difference in VRam load rates was 10-20%, now it does not correspond to reality at all. Moreover, if you still try to add something to the project, then the indicator shows 100% with overload!
