Joined: 11/22/2018(UTC) Posts: 94  Location: Worthing Thanks: 1 times Was thanked: 4 time(s) in 3 post(s)
I have a simple VB.net script that I am running before the stream starts and it plays a slidelshow then a few titles that I can update. I would like to add music to this but I haven't find a way to turn on the Audio input.
I have tried input.find("21").Function("AudioOn") but the audio on 21 is still not going to the output
Any tips?
API.Function("AudioOn", Input:=21)
thanks that works.
I have also tried SetVolumeFade API.Function("SetVolumeFade", Value:=0, Duration:=500, Input:=21) but I couldn't get that to work, obviously I'm misunderstanding the syntax. Any clues?
Joined: 12/27/2012(UTC) Posts: 5,530  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: FrankLeggett  thanks that works.
I have also tried SetVolumeFade API.Function("SetVolumeFade", Value:=0, Duration:=500, Input:=21) but I couldn't get that to work, obviously I'm misunderstanding the syntax. Any clues? Please check in the shortcut list for details !! Value should be volumelevel , duration !
Thanks doggy the shortcut list isn't specific.
this is what the shortcut list says "SetVolumeFade - Set volume gradually over x milliseconds. - Value = Volume 0-100,Milliseconds - Value,Input"
I have also tried API.Function("SetVolumeFade", Value:=0, 500, Input:=21) That causes an error when saving the script
If I understand you correctly I should instead enter API.Function("SetVolumeFade", Volumelevel:=0, Duration:=500, Input:=21)
The shortcut list doesn't say add "Duration" and it doesn't say "Volumelevel" basically it isn't obvious unless you have experience with syntax
Joined: 6/16/2020(UTC) Posts: 77  Thanks: 8 times Was thanked: 2 time(s) in 2 post(s)
