FrankLeggett
#1 Posted : Saturday, March 27, 2021 2:53:46 AM(UTC)
FrankLeggett
I have a simple VB.net script that I am running before the stream starts and it plays a slidelshow then a few titles that I can update. I would like to add music to this but I haven't find a way to turn on the Audio input.
I have tried
input.find("21").Function("AudioOn")
but the audio on 21 is still not going to the output
Any tips?
stigaard
#2 Posted : Saturday, March 27, 2021 8:46:34 AM(UTC)
stigaard
Denmark
API.Function("AudioOn", Input:=21)
FrankLeggett
#3 Posted : Saturday, March 27, 2021 6:31:35 PM(UTC)
FrankLeggett
thanks that works.
I have also tried SetVolumeFade
API.Function("SetVolumeFade", Value:=0, Duration:=500, Input:=21)
but I couldn't get that to work, obviously I'm misunderstanding the syntax. Any clues?
#4 Posted : Saturday, March 27, 2021 7:25:55 PM(UTC)
Originally Posted by: FrankLeggett Go to Quoted Post
thanks that works.
Please check in the shortcut list for details !!
Value should be volumelevel , duration !
FrankLeggett
#5 Posted : Saturday, March 27, 2021 8:13:03 PM(UTC)
FrankLeggett
Thanks doggy the shortcut list isn't specific.
this is what the shortcut list says
"SetVolumeFade - Set volume gradually over x milliseconds. - Value = Volume 0-100,Milliseconds - Value,Input"
I have also tried
API.Function("SetVolumeFade", Value:=0, 500, Input:=21)
That causes an error when saving the script
If I understand you correctly I should instead enter
API.Function("SetVolumeFade", Volumelevel:=0, Duration:=500, Input:=21)
The shortcut list doesn't say add "Duration" and it doesn't say "Volumelevel" basically it isn't obvious unless you have experience with syntax
Papo
#6 Posted : Sunday, March 28, 2021 1:12:02 PM(UTC)
Papo
Peru
