RickBrock
#1 Posted : Friday, November 20, 2020 7:40:05 PM(UTC)
RickBrock
Hi Everyone,
I'm struggling with something that's just confusing me :-(
I've got an akai midimix which I'm using happily for turning inputs off and on using shortcuts. I'm also enjoying the fact that the buttons light up when an input is active (by using activators)
BUT.... I can't get a button to light up when I use it to send buss B to my Master.
The button works using shortcuts, no problem.... I just don't know how to configure the activators section.
What do I put in 'Event' please?
Any help muchly appreciated
Thank You
Rick
#2 Posted : Friday, November 20, 2020 11:48:50 PM(UTC)
@ RickBrock
There is no direct "Event" that can be used for this, but a bit of a "workaround" is to use the "BusBVolume" Event.
You will need to use two Shortcut buttons, one for SendBusBToMasterOn and one for SendBusBToMasterOff.
Clone each one and apply a SetBusBVolume Shortcut to each, Value=100 for On button and Value=0 for Off button.
Set the Activator for the On button to BusBVolume.
This may or may not fit into your Workflow, but it is the only way I know of to use the "Activator" for what you describe.
(a feature request is likely in order...)
DSEGEV
#3 Posted : Saturday, January 30, 2021 1:03:01 AM(UTC)
DSEGEV
Israel
Originally Posted by: RickBrock Go to Quoted Post
Hi Everyone,
Thank You
Rick
Hi Rick,
I recently bought an AKAI MIDIMIX as well, but for some reason I can't light up my buttons. I've tried the all AKAI models under activators section in Vmix. Can you pls tell me how you did it?
RickBrock
#4 Posted : Saturday, January 30, 2021 2:54:52 AM(UTC)
RickBrock
@DSEGEV
My setting is this (obvs the notes and inputs will change for you)
Control : Note
channel:1 Note:9 to 0
Event: inputaudio
Input: 5 input
Assign activator to input number: yes
Type: AKAI APCmini Square
Green solid
I hop that helps
DSEGEV
#5 Posted : Saturday, January 30, 2021 11:27:35 PM(UTC)
DSEGEV
Israel
Hi Rick,
Thanks for you answer!
In my setup I have 4 xkeys keyboard to control video (Pvw/pgm/multiview and etc) and now Midi mix for audio.
I manage the activators to work with the midi mix only when the midi channel is 1. Before that I set it up on channel 6 and it wasn't working.
KeithRoberson
#6 Posted : Tuesday, March 16, 2021 4:13:13 PM(UTC)
KeithRoberson
@DSEGEV
Control : Note
Event: inputaudio
Input: 5 input
Green solid mygroundbiz
I hop that helps
Just what I needed, worked a treat, thank you!
DSEGEV
#7 Posted : Wednesday, March 17, 2021 2:29:57 AM(UTC)
DSEGEV
Israel
I succeed to do that already, only when I changed the akai to work on midi channel 1. before that it was configured on channel 4, and the activators didn't work.
Thanks!
@DSEGEV
Control : Note
Event: inputaudio
Input: 5 input
Green solid
I hop that helps
