4 Pages123>»
#1 Posted : Monday, March 8, 2021 3:23:47 PM(UTC)
Was thanked: 4740 time(s) in 1626 post(s)
vMix 24 has been released!
Visit the download page below to download and view all the changes:
http://www.vmix.com/software/download.aspx
Feedback
Please report any bugs or questions in this thread.
Thanks,
thanks 13 users thanked admin for this useful post.
eduardocfs on 3/8/2021(UTC), Roi on 3/8/2021(UTC), DWAM on 3/8/2021(UTC), richardgatarski on 3/8/2021(UTC), RichDanby on 3/8/2021(UTC), stigaard on 3/8/2021(UTC), ask on 3/8/2021(UTC), doggy on 3/8/2021(UTC), kayllastudio on 3/8/2021(UTC), kricher1964 on 3/8/2021(UTC), QuiapoChurch on 3/9/2021(UTC), raugert on 3/10/2021(UTC), AVStream on 3/10/2021(UTC)
cookdoeyl
#2 Posted : Monday, March 8, 2021 3:52:09 PM(UTC)
cookdoeyl
Was thanked: 8 time(s) in 6 post(s)
Very minor. If the PlayList window is open, and the selected playlist is changed via a shortcut (eg. Web Controller or StreamDeck), the list changes as expected, but the dropdown doesn't (until the window is closed and reopened).
carlofornasari
#3 Posted : Monday, March 8, 2021 9:21:29 PM(UTC)
carlofornasari
First of all, thanks for renaming overlay/layers. It gets very confusing when talking to other users about this feature.
Found one!
When you have engaged the border feature,
If you are cropping layers inside an input, the right and bottom edge don't align with the border. I believe it's the border that is misaligned.
image of issue
art23
#4 Posted : Monday, March 8, 2021 9:48:32 PM(UTC)
art23
VST3 plugins disappears in list input when next item start to play
Roi
#5 Posted : Monday, March 8, 2021 9:55:58 PM(UTC)
Roi
Philippines
I like the alerts feature and borders!
#6 Posted : Tuesday, March 9, 2021 12:45:54 AM(UTC)
This only occurs on the colour input as it has a low resolution by design.
Use it on a full HD source and it will work as expected.
doggy on 3/9/2021(UTC)
#7 Posted : Tuesday, March 9, 2021 12:46:27 AM(UTC)
VST is not currently supported for List inputs. Use a Bus instead and route the list input audio to that bus
then that bus back to master.
mrpap
#8 Posted : Tuesday, March 9, 2021 1:41:39 AM(UTC)
mrpap
Views messages in topic : 17
I updated without thinking, can i roll back for now?
craigreilly
#9 Posted : Tuesday, March 9, 2021 3:25:42 AM(UTC)
craigreilly
Yes - you can even dual install.
https://cdn.vmix.com/download/vmix23.exe
twokingsfilms
#10 Posted : Tuesday, March 9, 2021 7:54:43 AM(UTC)
twokingsfilms
First off LOVE THE UPDATES! Borders!!!!!! Aahhh!
Quick question on the borders situation - I only briefly had a chance to test it this morning. It appears that the borders don't "stick" with the input on a Merge transition. Instead they seem to fade off and back on. Can anyone confirm if that is indeed the case?
Again, thanks for the awesome updates!!
kaduramos
#11 Posted : Tuesday, March 9, 2021 8:50:24 AM(UTC)
kaduramos
Brazil
Was thanked: 11 time(s) in 5 post(s)
After update for this 24 version all my entries are black, video, Title, not show anything , sound is ok, but video no more
What can i do?
kross
#12 Posted : Tuesday, March 9, 2021 9:08:57 AM(UTC)
kross
Was thanked: 46 time(s) in 45 post(s)
What can i do?
You can roll back to v23. craigreilly posted a link a couple posts up.
gpdipalmerahtimur
#13 Posted : Tuesday, March 9, 2021 12:45:30 PM(UTC)
gpdipalmerahtimur
Indonesia
How do I clear Input set to Dynamic Input to prevent another Trigger that use the same Dynamic Input with different function?
Thanks in advance.
carlito
#14 Posted : Tuesday, March 9, 2021 11:44:44 PM(UTC)
carlito
Jamaica
Using a radius on a border, the original image corners aren't cropped to the curve.
Screenshot 2021-03-09 084319.png (212kb) downloaded 24 time(s).
#15 Posted : Tuesday, March 9, 2021 11:51:22 PM(UTC)
Not a bug. One should read the helpfiles : Borders Restrictions and Limitations
Roi
#16 Posted : Wednesday, March 10, 2021 12:17:10 AM(UTC)
Roi
Philippines
you can use luma key, if you wanted to crop the edges.
umek
#17 Posted : Wednesday, March 10, 2021 4:00:23 AM(UTC)
umek
Nice job vMix team!
BTW Faith of the Heart? :D
Monday Production
#18 Posted : Wednesday, March 10, 2021 7:50:45 AM(UTC)
Monday Production
Views messages in topic : 23
Norway
Hi!
Finally it´s out of beta, and I looking forward to start using it in real productions soon :-)
I was playing around with the new border function in conjunction with the use of virtual inputs and the merge transition.
I found out that there might be a bug when using the "MoveMultiViewOverlay" as trigger, the shortcut seems to works fine.
But when having vMix moving a Layer/MultiView triggered at transition in, in makes a copy of the Layer and not just moving it.
I did test the exact same preset in vMix 23 and it works fine there, of course without the borders in 23.
EDIT:
After re-importing the preset without borders back into vMix 24 it works fine to,
so it seems like when you start adding borders to all the MultiView/Layers the problem starts, and the Layers do not move correctly.
Kim
#19 Posted : Wednesday, March 10, 2021 3:14:41 PM(UTC)
The MoveMultiViewOverlay issue has now been fixed in the latest update
Roi on 3/10/2021(UTC)
pm
#20 Posted : Thursday, March 11, 2021 3:49:27 AM(UTC)
pm
Was thanked: 33 time(s) in 28 post(s)
Hi
I probably found a bug in 24 regarding IRP. The behaviour of 23 is different as a reference.
IRP is always in A/B synced mode.
23)
- Select existing event
- Play selected event with shortcut "ReplayPlaySelectedEventToOutput"
- While playing the event, create a new event with shortcut "ReplayMarkInOutLive"
- The playing event continues to play and a new event is created/tagged
-> good
24)
- The playing event is stopped, the output switches back to live camera and a new event is created/tagged
-> not good
The behaviour in 23 is important for sports productions: If something happens during an ongoing playing event, we can at least tag a new event for later usage. Sure, we can not edit it. But that's not a problem in a A/B synced mode only workflow.
Why I'm thinking it's a bug in 24: Creating the event with shortcuts "ReplayMarkInLive" and "ReplayMarkOut" (instead of "ReplayMarkInOutLive") doesn't stop the playing event in 24.
Could you please restore the functionality of the shortcut "ReplayMarkInOutLive" in 24 as it was in 23?
Thank you!
Best regards,
Patrick
Guest (10)
4 Pages123>»
