Joined: 1/13/2010(UTC) Posts: 5,367  Location: Gold Coast, Australia Was thanked: 4790 time(s) in 1644 post(s)
 13 users thanked admin for this useful post.
eduardocfs on 3/8/2021(UTC), Roi on 3/8/2021(UTC), DWAM on 3/8/2021(UTC), richardgatarski on 3/8/2021(UTC), RichDanby on 3/8/2021(UTC), stigaard on 3/8/2021(UTC), ask on 3/8/2021(UTC), doggy on 3/8/2021(UTC), kayllastudio on 3/8/2021(UTC), kricher1964 on 3/8/2021(UTC), QuiapoChurch on 3/9/2021(UTC), raugert on 3/10/2021(UTC), AVStream on 3/10/2021(UTC)
Joined: 12/12/2018(UTC) Posts: 23  Thanks: 1 times Was thanked: 8 time(s) in 6 post(s)
Very minor. If the PlayList window is open, and the selected playlist is changed via a shortcut (eg. Web Controller or StreamDeck), the list changes as expected, but the dropdown doesn't (until the window is closed and reopened).
Joined: 7/5/2019(UTC) Posts: 28  Location: Sydney Was thanked: 5 time(s) in 4 post(s)
First of all, thanks for renaming overlay/layers. It gets very confusing when talking to other users about this feature. Found one! When you have engaged the border feature, If you are cropping layers inside an input, the right and bottom edge don't align with the border. I believe it's the border that is misaligned.
VST3 plugins disappears in list input when next item start to play
Joined: 6/18/2020(UTC) Posts: 26   Location: Manila Thanks: 57 times Was thanked: 3 time(s) in 3 post(s)
I like the alerts feature and borders!
Originally Posted by: carlofornasari  When you have engaged the border feature,
This only occurs on the colour input as it has a low resolution by design. Use it on a full HD source and it will work as expected.
Originally Posted by: art23  VST3 plugins disappears in list input when next item start to play VST is not currently supported for List inputs. Use a Bus instead and route the list input audio to that bus then that bus back to master.
Joined: 1/5/2021(UTC) Posts: 17  Location: READING Thanks: 1 times
I updated without thinking, can i roll back for now?
Joined: 7/24/2020(UTC) Posts: 12  Location: AZ Was thanked: 1 time(s) in 1 post(s)
Joined: 5/19/2020(UTC) Posts: 23  Thanks: 2 times Was thanked: 1 time(s) in 1 post(s)
First off LOVE THE UPDATES! Borders!!!!!! Aahhh!
Quick question on the borders situation - I only briefly had a chance to test it this morning. It appears that the borders don't "stick" with the input on a Merge transition. Instead they seem to fade off and back on. Can anyone confirm if that is indeed the case?
Again, thanks for the awesome updates!!
Joined: 2/28/2021(UTC) Posts: 15  Location: São Paulo Thanks: 2 times Was thanked: 11 time(s) in 5 post(s)
After update for this 24 version all my entries are black, video, Title, not show anything , sound is ok, but video no more What can i do?
Joined: 10/31/2020(UTC) Posts: 205  Thanks: 6 times Was thanked: 46 time(s) in 45 post(s)
Originally Posted by: kaduramos  After update for this 24 version all my entries are black, video, Title, not show anything , sound is ok, but video no more What can i do? You can roll back to v23. craigreilly posted a link a couple posts up.
Joined: 6/5/2020(UTC) Posts: 91  Location: Jakarta Thanks: 17 times Was thanked: 5 time(s) in 3 post(s)
How do I clear Input set to Dynamic Input to prevent another Trigger that use the same Dynamic Input with different function?
Thanks in advance.
Using a radius on a border, the original image corners aren't cropped to the curve.  Screenshot 2021-03-09 084319.png (212kb) downloaded 24 time(s).
Joined: 12/27/2012(UTC) Posts: 5,537  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
Originally Posted by: carlito  Using a radius on a border, the original image corners aren't cropped to the curve.
Not a bug. One should read the helpfiles : Borders Restrictions and Limitations
Originally Posted by: carlito  Using a radius on a border, the original image corners aren't cropped to the curve.  Screenshot 2021-03-09 084319.png (212kb) downloaded 24 time(s). you can use luma key, if you wanted to crop the edges.
Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Nice job vMix team!
BTW Faith of the Heart? :D
Hi!
Finally it´s out of beta, and I looking forward to start using it in real productions soon :-)
I was playing around with the new border function in conjunction with the use of virtual inputs and the merge transition.
I found out that there might be a bug when using the "MoveMultiViewOverlay" as trigger, the shortcut seems to works fine. But when having vMix moving a Layer/MultiView triggered at transition in, in makes a copy of the Layer and not just moving it.
I did test the exact same preset in vMix 23 and it works fine there, of course without the borders in 23.
EDIT:
After re-importing the preset without borders back into vMix 24 it works fine to, so it seems like when you start adding borders to all the MultiView/Layers the problem starts, and the Layers do not move correctly.
Kim
The MoveMultiViewOverlay issue has now been fixed in the latest update
Thanks: 12 times Was thanked: 33 time(s) in 28 post(s)
Hi
I probably found a bug in 24 regarding IRP. The behaviour of 23 is different as a reference.
IRP is always in A/B synced mode.
23) - Select existing event - Play selected event with shortcut "ReplayPlaySelectedEventToOutput" - While playing the event, create a new event with shortcut "ReplayMarkInOutLive" - The playing event continues to play and a new event is created/tagged -> good
24) - Select existing event - Play selected event with shortcut "ReplayPlaySelectedEventToOutput" - While playing the event, create a new event with shortcut "ReplayMarkInOutLive" - The playing event is stopped, the output switches back to live camera and a new event is created/tagged -> not good
The behaviour in 23 is important for sports productions: If something happens during an ongoing playing event, we can at least tag a new event for later usage. Sure, we can not edit it. But that's not a problem in a A/B synced mode only workflow.
Why I'm thinking it's a bug in 24: Creating the event with shortcuts "ReplayMarkInLive" and "ReplayMarkOut" (instead of "ReplayMarkInOutLive") doesn't stop the playing event in 24.
Could you please restore the functionality of the shortcut "ReplayMarkInOutLive" in 24 as it was in 23?
Thank you!
Best regards, Patrick
