rickroyston
#1 Posted : Tuesday, March 9, 2021 12:02:46 AM(UTC)
rickroyston
It worked and then quit. Launching GT Title no longer gets me to the template screen. Suggestions? I can't seem to see the proper way to exit.
#2 Posted : Tuesday, March 9, 2021 12:42:39 AM(UTC)
What do you mean , can you be more specific plus what version and license
rickroyston
#3 Posted : Friday, March 12, 2021 1:30:59 AM(UTC)
rickroyston
A little hard to explain, but I'll try. At one time when I selected GTDesigner if went to a screen that had a page full of templates that I could select. On the top of that screen was the option to browse a custom .gzip. Now when I select GT Title Designer it goes directly into the program and bypasses the template options. I am running the HD version.
Thanks for your response,
Rick
#4 Posted : Friday, March 12, 2021 1:40:27 AM(UTC)
I guess you meant when you want to add a new title input or change a current one , not the title designer (for creating titles) nor title editor for editing the text
check bottom right for the Add Input button and select title or to change the current title input clicking on the cogwheel lower left of a title input , select general tab and press the change button.
Helpfiles have lots of info
rickroyston
#5 Posted : Friday, March 12, 2021 1:58:50 AM(UTC)
rickroyston
I found my answer. The launch of the title browser is from Settings-> Title/XMAL. As often the case a user error!
#6 Posted : Friday, March 12, 2021 2:04:06 AM(UTC)
Good find ;-) but from Settings is wrong
