GT
GT Title Templates
It worked and then quit. Launching GT Title no longer gets me to the template screen. Suggestions? I can't seem to see the proper way to exit.
Joined: 12/27/2012(UTC) Posts: 5,520  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: rickroyston  Launching GT Title no longer gets me to the template screen. What do you mean , can you be more specific plus what version and license
A little hard to explain, but I'll try. At one time when I selected GTDesigner if went to a screen that had a page full of templates that I could select. On the top of that screen was the option to browse a custom .gzip. Now when I select GT Title Designer it goes directly into the program and bypasses the template options. I am running the HD version.
Thanks for your response, Rick
Originally Posted by: rickroyston  A little hard to explain, but I'll try. At one time when I selected GTDesigner if went to a screen that had a page full of templates that I could select. On the top of that screen was the option to browse a custom .gzip. Now when I select GT Title Designer it goes directly into the program and bypasses the template options. I am running the HD version.
I guess you meant when you want to add a new title input or change a current one , not the title designer (for creating titles) nor title editor for editing the text check bottom right for the Add Input button and select title or to change the current title input clicking on the cogwheel lower left of a title input , select general tab and press the change button. Helpfiles have lots of info
I found my answer. The launch of the title browser is from Settings-> Title/XMAL. As often the case a user error!
Originally Posted by: rickroyston  I found my answer. The launch of the title browser is from Settings-> Title/XMAL. As often the case a user error! Originally Posted by: doggy  check bottom right for the Add Input button
Good find ;-) but from Settings is wrong
GT
GT Title Templates
