Vince Beck
#1 Posted : Friday, February 19, 2021 11:50:15 AM(UTC)
Vince Beck
I've seen a few posts about recommending appending to replace with new VMixcall numbers.
In my case, I want a preset that just replaces the first 6 (NDI) inputs with VMix Call to switch shows during a quick break. But whithout shutting down VMix.
No matter what I try, it just adds the inputs at the end of my (yikes) 78 inputs. Has anyone found a way to just replace the top inputs?
elvis55
#2 Posted : Friday, February 19, 2021 8:32:27 PM(UTC)
elvis55
Switzerland
Hi Vince Beck
There is no function. It is automatically inserted in the last position.
Best to post in feature requests.
Martin can possibly add the "INPUT NUMBERING" function, as when creating a new input, where the position number can be selected below.
#3 Posted : Friday, February 19, 2021 8:59:45 PM(UTC)
There is a moveinput function and there is scripting allowing you to check an inputs positions, the type of inputs etc
Manually moving an input by right clicking the inputs cogwheel ...
elvis55
#4 Posted : Friday, February 19, 2021 9:57:21 PM(UTC)
elvis55
Switzerland
Hi Doggy,
This function is known. But it is easier if you can enter the position when adding, as when creating a new input.
INPUT NUMBERING
https://forums.vmix.com/...s/t20734-INPUT-NUMBERING
#5 Posted : Saturday, February 20, 2021 12:27:00 AM(UTC)
is adding(inserting) not the same as creating here ?
presets (as the name implies: prepared setup ups) can be loaded to replace an existing setup without having to restart vMix
Besides there is a change option in the general tab of an input (top right)
elvis55
#6 Posted : Saturday, February 20, 2021 12:56:15 AM(UTC)
elvis55
Switzerland
As I understand Vince Beck, he wants to open a preset to add calls.
When he clicks on "Apppend", the inbox is added last.
If it has 78 inputs, the new input becomes 79.
However, it is easier if you can enter the position as you add it when creating a new entry.
https://www.vmix.com/hel...ndex.htm?OpenPreset.html
#7 Posted : Saturday, February 20, 2021 1:06:05 AM(UTC)
IC
would mean you would almost have to specify that for each input to append
IMO quicker to just have a script that checks which inputs are calls and move them to the front (one key to call the script). JMO
mark2020
#8 Posted : Monday, February 22, 2021 3:22:16 PM(UTC)
mark2020
I put out the question about the possibility of a ReplaceInput function a few days ago and subsequently added it to feature requests. It sounds very similar, or closer to what you're looking for, than moving inputs around.
The added power is that with a parameter to Replace with a virtual input, your NDI & vMixCall inputs could be up in the higher numbers, and you'd be replacing 1-6 virtual inputs with virtual inputs, thus not destroying the existing NDI or Call inputs. And retaining multiview and other settings in 1-6.
Guest (5)
