Hi all, I have an issue with my Kona 3G card....it was working fine until I did an update, now I can not see it in vMix as an input as before....I saw all 4 inputs and now, I can not get the drivers to work....ir shows in Device Manager, but the drivers would not load, and the DirectShow filters keep returning errors when trying to install....
Help is really needed here..
Thanks in advance...
Joined: 2/13/2021(UTC) Posts: 3  Location: Fairfield Thanks: 1 times
Same thing happened today with an AJA Corvid44 card. Was working in 21 and did update to 23 and now it is not showing up in the AJA control panel or vMix.
If anyone have drivers that can work I will be so happy....it seems that the windows 10 2004, kills a lot of other drivers as well....gave me problems with my editor....lucky I was able to get some help.....but this is so sad, and none of the updated drivers from AJA seem to work....now I see it is showing up in Device Manager, but still no drivers seem to work...works on a windows 8.1 system, and older windows 10 machine, but after updates, it is no longer working.....
It is working on my windows 8.1 PC, and it worked well on the windows 10 PC when I first installed it, but now I am having all sorts of issues....now it is showing up, but as soon as I add a camera, the card disappears in vMix, but still shows in Device Manager
