52 Pages«<3031323334>»
HuperSom
#621 Posted : Wednesday, February 10, 2021 1:59:20 PM(UTC)
HuperSom
Portugal
Captura de ecra 2021-02-10, as 03.40.36.png (1,741kb) downloaded 6 time(s).
I leave here the part of the Audio matrix to work perfectly, only the icons of the Bus mutes do not activate, maybe some error when calling the BuxXAudio function.
Is there how to solve?
KMR
#622 Posted : Wednesday, February 10, 2021 2:13:22 PM(UTC)
KMR
Ireland
Originally Posted by: HuperSom Go to Quoted Post
The Builder Panel does not call the cameras to the Virtual Set Boxes.
In this example of Image Matrix for the boxes of the virtual Set I would be calling Call 1 for Box 2, but it does not answer.…
What is wrong?
I don't use Virtual Sets, I use multiviews. SetMultiviewOverlay works with multiviews. I don't see any functions in the help doc for virtual sets.
raugert
#623 Posted : Wednesday, February 10, 2021 3:27:15 PM(UTC)
raugert
Canada
The command "SetMultiviewOverlay" requires (Index,Input) in the "Value" field.. Refer to vMix User Guide in the "Shortcuts" chapter.
example:
Screen Shot 2021-02-09 at 11.22.22 PM.png (1,162kb) downloaded 4 time(s).
thanks 1 user thanked raugert for this useful post.
HuperSom on 2/10/2021(UTC)
raugert
#624 Posted : Wednesday, February 10, 2021 3:37:09 PM(UTC)
raugert
Canada
Although it's not in the API shortcuts list, the command "SetMultiviewOverlay" works for changing the Input within the virtual set layers... Enter (Index,Input) in the "Value field.
raugert
#625 Posted : Wednesday, February 10, 2021 3:59:23 PM(UTC)
raugert
Canada
Yes it appears I broke this in 4.0.29. Sorry, I will fix it in next update...
Richard
HuperSom
#626 Posted : Wednesday, February 10, 2021 4:08:24 PM(UTC)
HuperSom
Portugal
Richard
Detectei que o comando SetMultiViewOverlay tem o mesmo problema
Veja o exemplo que disponebilizei aqui: https://forums.vmix.com/...ilder---Layer-para-Calls
Parabens pelo excelente trabalho
HuperSom
#627 Posted : Wednesday, February 10, 2021 4:22:19 PM(UTC)
HuperSom
Portugal
Como posso adicionar os comandos para as 4 câmaras virtuais do Virtual Set ?
What are you wanting to do with the Virtual Set inputs ?
There are limited functions available in the API for Virtual Sets.
1. You can transition to them like any other Input.
2. You can also zoom into a preset using the "SetIndex" command.
That's about it. Any other settings must be done within vMix itself.
I can't find SetIndex on any of the command tabs, do you know where it is?
raugert
#628 Posted : Wednesday, February 10, 2021 5:31:30 PM(UTC)
raugert
Canada
My mistake :( ... it's actually "SelectIndex" ...
command: InputSelect > SelectIndex
HuperSom
#629 Posted : Thursday, February 11, 2021 12:46:08 AM(UTC)
HuperSom
Portugal
As a SelectIndex function the button doesn't even seem to work.
I am also not sure that the Cameras Index is 1,2,3,4
See if I'm doing something wrong?
Thank you
Captura de ecra 2021-02-10, as 14.41.17.png (819kb) downloaded 9 time(s).
raugert
#630 Posted : Thursday, February 11, 2021 1:19:49 AM(UTC)
raugert
Canada
The "SelectIndex" command in a virtual set is used to Zoom into the selected preset (Reference vMix User Guide page 195). Enter 1-4 into the Value field according to the camera preset you wish to zoom into..
Screen Shot 2021-02-10 at 9.24.08 AM.png (1,104kb) downloaded 7 time(s).
HuperSom on 2/11/2021(UTC)
Marvin
#631 Posted : Thursday, February 11, 2021 1:51:10 PM(UTC)
Marvin
I dont know for sure but it look like there is a problem with the infobox, is no work propertly.
raugert
#632 Posted : Saturday, February 13, 2021 1:11:09 AM(UTC)
raugert
Canada
Can you elaborate... InfoBox doesn't open ?
HuperSom
#633 Posted : Saturday, February 13, 2021 1:28:17 PM(UTC)
HuperSom
Portugal
I leave some suggestions that were very pleasing.
Rotary Buttons for Panoramics, Gains, Compressors, Gates, Delays, etc ...
Graphic equalizer
Possibility to create and edit subtitles in Builder
raugert
#634 Posted : Sunday, February 14, 2021 4:04:51 PM(UTC)
raugert
Canada
@Hupersum
Graphic equalizer
Most of these controls (except Gain) are not available in the vMix API. It is not currently possible to add this in the Panel Builder.
joeldinbud
#635 Posted : Monday, February 15, 2021 11:24:13 PM(UTC)
joeldinbud
When I clone a button it is being added automatically to pages 2, 3, etc. If I delete it from the extra pages it is deleted on Page 1 as well. Thoughts?
Newest version: 4.0.29
raugert
#636 Posted : Tuesday, February 16, 2021 1:19:09 AM(UTC)
raugert
Canada
Sorry joelinbud. I'm unable to duplicate your cloning issue. This was fixed in 4.0.27...
Does this happen on a new template or a previously made template ? If it's an old template, can you send me a copy at info@studio793.ca I'll have a look at it to see if anything may be causing this...
thanks,
Richard
sinc747
#637 Posted : Monday, March 1, 2021 4:59:49 AM(UTC)
sinc747
Was thanked: 204 time(s) in 170 post(s)
Richard,
Kudos for such great work over such a long period of time! I am now a big fan!
Keep it up!
- Tom
raugert on 3/1/2021(UTC)
Joeboe
#638 Posted : Monday, March 1, 2021 10:07:36 AM(UTC)
Joeboe
Form the first time I used this app, I liked it.....and wit all the new improvements, this is the BEST software switcher I ever used....I can design my own buttons, lay them out how I like, and it works great....I posted a few samples of my layouts, but I am always looking for new button styles.
thanks 1 user thanked Joeboe for this useful post.
sinc747
#639 Posted : Monday, March 1, 2021 12:43:45 PM(UTC)
sinc747
At the moment I am not in a place where I can test this, but can more than one instance of PB be run on the same PC?
So if I want to control my main PC and a second PC on my same network, can I use two instances of PB with appropriate changes to the Preferences vMix IP field?
- Tom
raugert
#640 Posted : Monday, March 1, 2021 1:54:12 PM(UTC)
raugert
Canada
Hi Tom,
Thanks for the accolades and checking out the app. It's not perfect, but I'm glad some folks are using it.
Yes, you can run 2 instances on a PC to control separate vMix machines.
cheers,
Richard
Edit: I hope I didn't speak too soon. I know you can run 2 instances of the app, but I haven't tested to see if it can control 2 vMix machines simultaneously. (but it should)
You can only save the preferences for one instance of the app, so you would have to change the vMix IP each time you load the app.
Guest (11)
