Feature Requests
GT Title Designer Anchor Point Problem
You have been a member since:: 1/13/2018(UTC) Posts: 74
Thanks: 11 times Was thanked: 7 time(s) in 4 post(s)
I messaged vmix regarding a problem I had with GT Title designer anchor point for text bounding, and was told that this was not possible at the moment but to add it as a feature request..so here I am. When making titles using the text bounding option, I would like to be able to have the text growing to the left instead of always having to expand to the right. I hope this makes sense, but it is shown better in the following video. As you can see at the end when I add the 2 "Fs"the bounding box expands only to the right would be great if the white/pink box could stay where it as (on the right hand side and the text expands to the left, instead of the right.
 2 users thanked Quinton for this useful post.
+1, as well as growing both ways (for centered texts). I sort of assumed it would work this way too, only used expand right so far.
Joined: 10/10/2017(UTC) Posts: 5 Location: Sydney, AUS
Originally Posted by: richardgatarski  +1, as well as growing both ways (for centered texts). I sort of assumed it would work this way too, only used expand right so far. +1
+1 for this also. This is essential for sportscasts.
Joined: 1/25/2019(UTC) Posts: 335  Thanks: 24 times Was thanked: 88 time(s) in 68 post(s)
Joined: 12/30/2019(UTC) Posts: 10  Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
+1 And also if it is no text, to do not shown 1pxl bounded rectangle...
Joined: 5/20/2017(UTC) Posts: 63   Location: Philippines Thanks: 179 times Was thanked: 3 time(s) in 2 post(s)
Joined: 3/13/2019(UTC) Posts: 7  Location: Dubai Was thanked: 1 time(s) in 1 post(s)
This looks like a half-baked feature in general, even rotating a text object by 180 degrees along the X axisdoes not affect the anchor point. For RTL scripts it is a real bummer, if one wants to use a natural in such a case right aligned text growing to the left.
Joined: 11/25/2019(UTC) Posts: 43  Location: Bordeaux Was thanked: 2 time(s) in 2 post(s)
Joined: 6/9/2020(UTC) Posts: 2  Location: Saint-Petersburg
+1 Plus the same behaviour for Center alignment of text - I would want to use this feature for titling, I use 'speaking head' window (~70% scale) placed in the centre of fullframe background. And would want to title different speakers using DataSource. Titles should be aligned in the centre below a 'speaking head'
Joined: 1/25/2018(UTC) Posts: 15   Thanks: 4 times Was thanked: 1 time(s) in 1 post(s)
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
Joined: 7/15/2018(UTC) Posts: 110  Location: Las Vegas, NV Thanks: 14 times Was thanked: 9 time(s) in 7 post(s)
+1. Have requested this for a bit.
Joined: 3/9/2019(UTC) Posts: 24  Location: Victoria, BC Thanks: 5 times Was thanked: 1 time(s) in 1 post(s)
Joined: 9/22/2020(UTC) Posts: 45  Thanks: 3 times Was thanked: 5 time(s) in 5 post(s)
+1 Im surprise its not done already, its more like an uncomplete feature imho
Joined: 5/24/2019(UTC) Posts: 8  Location: Pasay Thanks: 1 times Was thanked: 2 time(s) in 1 post(s)
Joined: 10/6/2020(UTC) Posts: 98  Was thanked: 21 time(s) in 21 post(s)
+1
This might seem like a minor issue, but the current state - where text boxes only expand to the left - makes it impossible to implement a right-aligned client title design.
Feature Requests
