Joined: 4/22/2020(UTC) Posts: 11  Location: Sneem Thanks: 4 times Was thanked: 2 time(s) in 2 post(s)
I use VMIX to stream to twitch and was wondering if it is possible to get the Follows and raid's bit's etc to pop up over the main video feed?
Rank:: Advanced Member
Thanks: 4 times Was thanked: 10 time(s) in 10 post(s)
Hello. Add a browser input and insert a link to streamlabs or other notifications.
Set this browser input as overlay. There are 1-4 buttons at the bottom of each input.
 1 user thanked andreypetr for this useful post.
Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
Hey Madypaddy, wondering if you tried out andreypetr's suggestion. I'm going down the same path, and I thought I'd see if you had any insights? Thanks in advance!
Originally Posted by: Geoff B  Hey Madypaddy, wondering if you tried out andreypetr's suggestion. I'm going down the same path, and I thought I'd see if you had any insights? Thanks in advance! Hey Geoff ya it works perfectly let me know if you have any problems.
So, I have SLOBS but I haven't ever used it. I didn't get the browser part of the equation... I know how to put a browser input into vMix, but how do I make a browser output from SLOBS?
Hi Geoff first link SLOBS with your twitch account . Then go to Dashboard in SLOBS go to alert box and setup your alert's like follower/Raid etc in there you will see a link to test each alert and it will have a URL link in a browser for each alert . go back to SLOBS and create a new scene and click the + sign to add each alert to sources. Right click on the source you added select properties and you can get the url there. Then just add them to Vmix if you still have trouble I can post some images
 1 user thanked Madpaddy for this useful post.
Thank you so much! Looking forward to trying this out. And thanks to andreypetr too for the original reply!
