shinyidol
#1 Posted : Wednesday, September 25, 2019 6:19:33 PM(UTC)
shinyidol
Installed the latest vMix on a new laptop and tried to get twitch logged in and got the following error.
The remote server returned an error: (410) Gone.
Provider.Login
Any clues what is going on here?
I'm able to login to Twitch with the same l/p as I'm entering in vMix.
Shad0w59
#2 Posted : Thursday, September 26, 2019 11:27:00 AM(UTC)
Shad0w59
I had this problem as well and could not find a solution.
A workaround however is to stream to a Custom RTMP Server instead of Twitch in the dropdown.
Find the Twitch server with the best connection for you and enter your stream key:
https://stream.twitch.tv/ingests/
You can use this RTMP URL as your custom streaming destination.
