MarshallDungan
#1 Posted : Wednesday, December 23, 2020 9:23:02 AM(UTC)
MarshallDungan
I've been testing some new gear setups:
Sony Z90
Elgato Cam Link 4k
Rode Wireless Go into Z90
Testing going into a retina MacBook Pro (LED Bar) using Firefox browser.
After about 20 seconds of clean audio, the audio quality drops and there is notable scratchiness on the end of speech.
I've been combing through the support forum, and have thrown several different bandwidths and return bandwidths at it, gone peer-to-peer, but the audio degrades over time with every troubleshooting method.
What's more is, when using the onboard mic for audio (and the z90 video), the issue does not persist. When using a Sony AX53's onboard mic, the issue does not arise.
At the camera level on the z90, the audio is clean. So something is happening specifically with the Rode Wireless Go + Z90 that we can't figure out.
Open to any troubleshooting ideas.
Thanks,
Marshall
mavik
#2 Posted : Wednesday, December 23, 2020 9:47:19 AM(UTC)
mavik
I would try to isolate the issue.
Z90 build in mic = no issue
Z90 + Rode = issue
AX53 build in mic = no issue
AX53 + Rode = ??
See if the problem follows with some changes you make or if it doesn't. With that you know where the issue comes from. Then look into more detail what might be causing it.
MarshallDungan
#3 Posted : Wednesday, December 23, 2020 10:20:09 AM(UTC)
MarshallDungan
Z90 + Rode = issue
AX53 + Rode = ??
Right--Component Isolation at its finest! Here's what I've done so far:
Firefox
Macbook Pro
Z90
Rode Wireless GO
Vmix Call
Replacing vmix call with Zoom removes the problem (with all other conditions the same).
Replacing Camlink audio with Onboard Mic audio removes the problem (I believe from observation)
Replacing Macbook Pro with a Macbook AIR (seriously?) or different MacBook Pro removes the problem.
It appears to be something happening in the VMix call send machine.
mavik
#4 Posted : Wednesday, December 23, 2020 10:32:11 AM(UTC)
mavik
Have you tried advanced.vmixcall.com
It gives you more settings to play with.
MarshallDungan
#5 Posted : Thursday, December 24, 2020 4:06:39 AM(UTC)
MarshallDungan
To update:
I believe I have isolated the problem to the Macbook Pro (2019, 2 thunderbolt 3 ports); all other machines I've used do not have the problem. VMix Support says from the logs it's not VMix Call. So something about this machine...
2019 Macbook Pro
10.15.7 Catalina
1.4 GHz Quad Core i5
16 GB ram
Intel Graphics UHD 645 1538MB
...that is causing the audio scratchiness. It doesn't happen over any other machine.
