Joined: 12/10/2020(UTC) Posts: 4  Location: Kuala Lumpur
Hi guys, my vMix is crashing big time today caused by Grooveex.dll. Anyone got this problem before? I was working fine yesterday. Nothing was updated between now and then. This morning the program would stay on only for a minute before crashing. Thanks! Code:Faulting application name: vMix64.exe, version: 23.0.0.66, time stamp: 0x5fa393f2
Faulting module name: GROOVEEX.DLL, version: 16.0.12527.21322, time stamp: 0x5fa34595
Exception code: 0xc0000005
Fault offset: 0x0000000000006c82
Faulting process id: 0x%9
Faulting application start time: 0x%10
Faulting application path: %11
Faulting module path: %12
Report Id: %13
Faulting package full name: %14
Code:- <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
- <System>
<Provider Name="Application Error" />
<EventID Qualifiers="0">1000</EventID>
<Version>0</Version>
<Level>2</Level>
<Task>100</Task>
<Opcode>0</Opcode>
<Keywords>0x80000000000000</Keywords>
<TimeCreated SystemTime="2020-12-10T00:36:48.6686661Z" />
<EventRecordID>7073</EventRecordID>
<Correlation />
<Execution ProcessID="0" ThreadID="0" />
<Channel>Application</Channel>
<Computer>VMIX7</Computer>
<Security />
</System>
- <EventData>
<Data>vMix64.exe</Data>
<Data>23.0.0.66</Data>
<Data>5fa393f2</Data>
<Data>GROOVEEX.DLL</Data>
<Data>16.0.12527.21322</Data>
<Data>5fa34595</Data>
<Data>c0000005</Data>
<Data>0000000000006c82</Data>
</EventData>
</Event>
Joined: 7/28/2019(UTC) Views messages in topic : 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Another crash today after removing One Drive, at the end of the day. ntshrui.dll just happen out of the blue after being stable for the last 8 hours :( What gives??! Quote:Log Name: Application Source: Application Error Date: 12/10/2020 7:16:25 PM Event ID: 1000 Task Category: (100) Level: Error Keywords: Classic User: N/A Computer: VMIX7 Description: Faulting application name: vMix64.exe, version: 23.0.0.66, time stamp: 0x5fa393f2 Faulting module name: ntshrui.dll, version: 6.2.19041.610, time stamp: 0x80fd59b2 Exception code: 0xc0000005 Fault offset: 0x000000000001215f Faulting process id: 0x%9 Faulting application start time: 0x%10 Faulting application path: %11 Faulting module path: %12 Report Id: %13 Faulting package full name: %14 Faulting package-relative application ID: %15 Event Xml: <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event"> <System> <Provider Name="Application Error" /> <EventID Qualifiers="0">1000</EventID> <Version>0</Version> <Level>2</Level> <Task>100</Task> <Opcode>0</Opcode> <Keywords>0x80000000000000</Keywords> <TimeCreated SystemTime="2020-12-10T11:16:25.9471334Z" /> <EventRecordID>7660</EventRecordID> <Correlation /> <Execution ProcessID="0" ThreadID="0" /> <Channel>Application</Channel> <Computer>VMIX7</Computer> <Security /> </System> <EventData> <Data>vMix64.exe</Data> <Data>23.0.0.66</Data> <Data>5fa393f2</Data> <Data>ntshrui.dll</Data> <Data>6.2.19041.610</Data> <Data>80fd59b2</Data> <Data>c0000005</Data> <Data>000000000001215f</Data> </EventData> </Event>
Joined: 1/13/2010(UTC) Posts: 5,335  Location: Gold Coast, Australia Was thanked: 4735 time(s) in 1624 post(s)
The randomness of these errors indicates a fault on the system unfortunately, possibly driver or hardware related. A good first step would be to reinstall Windows in case something is corrupt and check for the latest drivers for everything.
Failing that begins the long process of replacing items one by one until the culprit is found.
These issues are extremely rare which makes it harder to know what the cause is. (For example these errors have never occurred on our systems here at vMix and we test many computers and laptops on a regular basis)
Martin vMix
Yes. That is my conclusion too.
But it was during an event and that option was not possible until the weekend. Luckily it was just handling in house tvs and not stage and broascast.
Btw, system is a few months old only. Hardware is:
- Ryzen 3 3800xt - 32gb ram - zotac 3070 - aver media gamer 4k
Problems only started recently after updating windows to latest available.
Will use your suggestion and check stability again.
Thanks.
Joined: 12/4/2016(UTC) Posts: 18   Location: Strasbourg Thanks: 3 times
Report a crash today during a stream on a brand new laptop ("Lenovo Legion 5 15ARH05H - Ryzen 7 4800H, 32 Go de RAM, 512 Go SSD, RTX 2060 (6 Go).
vmmix crashed (the software shutdown with no warning : I could relaunch and continued the stream). Latest drivers installed, temperature of the CPU was no more than 75°. First part of the stream lasted 2h43 minutes, 2nd part 1h30.
Here's the event viewer report :
Nom de l’application défaillante vMix64.exe, version : 23.0.0.66, horodatage : 0x5fa393f2 Nom du module défaillant : ntshrui.dll, version : 6.2.19041.610, horodatage : 0x80fd59b2 Code d’exception : 0xc0000005 Décalage d’erreur : 0x000000000001215f ID du processus défaillant : 0x%9 Heure de début de l’application défaillante : 0x%10 Chemin d’accès de l’application défaillante : %11 Chemin d’accès du module défaillant: %12 ID de rapport : %13 Nom complet du package défaillant : %14
Détecteur d'erreurs 2137556682621590693, type 4 Nom d’événement : APPCRASH Réponse : Non disponible ID de CAB : 0
Signature du problème : P1 : vMix64.exe P2 : 23.0.0.66 P3 : 5fa393f2 P4 : ntshrui.dll P5 : 6.2.19041.610 P6 : 80fd59b2 P7 : c0000005 P8 : 000000000001215f P9 : P10 :
Fichiers joints : \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA87C.tmp.WERInternalMetadata.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA89C.tmp.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA89B.tmp.csv \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA8CB.tmp.txt
Ces fichiers sont peut-être disponibles ici : \\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_vMix64.exe_2a6947eca8f322855915d1de82ef8158254bf_00000000_d49ef1cd-51ee-43a3-a877-d29002b62a99
Symbole d’analyse : Nouvelle recherche de la solution : 0 ID de rapport : d49ef1cd-51ee-43a3-a877-d29002b62a99 Statut du rapport : 268435456 Récipient avec hachage : 48f00e5b6ed003737daa207a42ec1ca5
