Trilback
#1 Posted : Monday, November 16, 2020 3:54:05 AM(UTC)
Trilback
You have been a member since:: 10/13/2020(UTC)
I want to be able to record from a focusrite sound card. The problem is I use it to output to a mixer board for songs and videos and input from a tape out on the mixer board. Is there a way in vmix to only have the input from the sound card be recorded but it not output back to the mixer as if I do that I get Echo from the wireless mic from the board and my output to the board from my input if this makes sense?
Trilback
#2 Posted : Monday, November 23, 2020 3:27:44 AM(UTC)
Trilback
bump
Vince Beck
#3 Posted : Monday, November 23, 2020 8:16:31 AM(UTC)
Vince Beck
Are you using audio busses in your settings?
You can select which inputs are sent to what bus/device.
Trilback
#4 Posted : Monday, November 23, 2020 10:32:47 AM(UTC)
Trilback
That worked perfectly. Thanks
