Joined: 10/13/2020(UTC) Posts: 24  Location: Annandale Thanks: 2 times
I want to be able to record from a focusrite sound card. The problem is I use it to output to a mixer board for songs and videos and input from a tape out on the mixer board. Is there a way in vmix to only have the input from the sound card be recorded but it not output back to the mixer as if I do that I get Echo from the wireless mic from the board and my output to the board from my input if this makes sense?
Joined: 7/28/2019(UTC) Views messages in topic : 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
Are you using audio busses in your settings?
You can select which inputs are sent to what bus/device.
That worked perfectly. Thanks
