3 Pages123>
#1 Posted : Friday, March 7, 2014 7:16:59 AM(UTC)
vMix 12 has been released!
Visit the download page below to download and view all the changes:
http://www.vmix.com.au/download.aspx
This is a recommended update for all users.
Upgrading from vMix 11 and earlier
If you purchased vMix on or after January 2013, you qualify for a free upgrade to vMix 12.
Simply click the Activate button when prompted in vMix.
If you purchased vMix prior to January 2013, read the following Knowledge Base article for upgrade options:
http://www.vmix.com.au/knowledgebase/article.aspx/31/upgrades
The cheapest upgrade option is only $55 USD.
Feedback
Please report any bugs or questions in this thread.
Thanks,
madness on 3/11/2014(UTC)
Ernest Król
#2 Posted : Friday, March 7, 2014 7:55:55 AM(UTC)
Ernest Król
is it normal that vMix doesn't display "vMix Audio"?
recording and streaming works as normal...
#3 Posted : Friday, March 7, 2014 8:16:18 AM(UTC)
Can you try installing again? It should definitely be there and also set as the default.
Is it possible you have it unticked when editing the capture names? It will need to be ticked otherwise
when you click OK in settings, it will switch to None and no audio will be recorded.
wwdv
#4 Posted : Friday, March 7, 2014 7:13:29 PM(UTC)
wwdv
Was thanked: 21 time(s) in 15 post(s)
What is recommended: Uninstalling the current version or just install vMix12 over the old version?
Ernest Król
#5 Posted : Saturday, March 8, 2014 8:01:28 AM(UTC)
Ernest Król
ok, my fault - "vMix Audio" was unchecked :P (but recording worked normally...)
Egriswold
#6 Posted : Saturday, March 8, 2014 10:44:52 AM(UTC)
Egriswold
Was thanked: 35 time(s) in 34 post(s)
Bug report, After importing files in to "Photo" module then selecting transition setting the slideshow starts to play in a loop immediately and will not stop.
#7 Posted : Saturday, March 8, 2014 10:48:22 AM(UTC)
Hi Ed,
That's correct, the transition dropdown selects the time for it to automatically move through each item in the list.
daniel514
#8 Posted : Saturday, March 8, 2014 1:00:06 PM(UTC)
daniel514
Canada
Was thanked: 16 time(s) in 16 post(s)
Hi
what are requirements to get Hardware Acceleration to MP4 Recording, i try but no cpu difference,i have GTX 660 2 GB
Thanks!
Egriswold
#9 Posted : Saturday, March 8, 2014 6:07:33 PM(UTC)
Egriswold
admin wrote:
Hi Ed,
Hey Martin,
I thought after selecting the transition time the module would wait to be triggered start either by manually clicking the play button or in the options setting that quick plays items when sent to program out.
#10 Posted : Wednesday, March 12, 2014 10:56:39 AM(UTC)
A small update has been released to vMix 12 (12.0.0.112)
Fixes:
* OverlayInputIn shortcut would not activate if Overlay was already in use by another input.
* OverlayInput shortcuts would not work if Overlay was currently being previewed.
* Default Audio Delay option added to Settings - Audio to allow fine tuning when using external mixer.
See: http://www.vmix.com.au/help12/RecordingAudio.html
* Audio Delay allows negative values for video clips
* Audio Delays up to 20 seconds can now be set
This update can found on the web site Download page.
ridi
#11 Posted : Wednesday, March 12, 2014 6:49:49 PM(UTC)
ridi
Hi Martin. I was looking Vmix 12 Trial, i used with blackmagic Intensity Pro with last driver of the card, and it has problem with audio, Audio go out break, i tested with Vmix 11 and its fine. Sorry for the english. Thank you.
#12 Posted : Wednesday, March 12, 2014 9:58:18 PM(UTC)
Could you describe in a bit more detail the audio issue? Perhaps check
the correct Recording audio device is selected in vMix Settings -> Audio. It should be vMix Audio by default.
ridi
#13 Posted : Thursday, March 13, 2014 5:51:59 AM(UTC)
ridi
Recording works fine, i have selected Vmix audio, but the audio that go out its bad, works fine about 1 hour and starts to break. Vmix audio out i set decklink audio and external out i set decklink audio and the same thing. I have 2 card 1 for input 1 for output, and audio input from card its brake.
#14 Posted : Thursday, March 13, 2014 7:41:05 AM(UTC)
So audio in the recording is fine, just not on the external output?
I am a bit confused by this "Vmix audio out i set decklink audio" as you should
only be setting decklink audio in the external output settings.
ridi
#15 Posted : Thursday, March 13, 2014 7:54:19 AM(UTC)
ridi
Audio recording its fine, only in external output its works bad, with Vmix 11 works fine both. I set Audio output direct sound and its the same, in external go break audio.
ridi
#16 Posted : Thursday, March 13, 2014 7:58:01 AM(UTC)
ridi
Can work Vmix with matrox rtx2?
#17 Posted : Thursday, March 13, 2014 8:14:49 AM(UTC)
What does the audio sound like? Can you list all of the settings you are using in External Output?
Try setting a small audio delay in External Output settings such as 40
ridi
#18 Posted : Thursday, March 13, 2014 8:19:07 AM(UTC)
ridi
Audio output: decklink audio
Recording Audio: Vmix Audio
External output device: Decklink
Audio device: decklink audio
hassan yaghi
#19 Posted : Thursday, March 13, 2014 10:50:46 AM(UTC)
hassan yaghi
Confirmed , vmix 12 external audio output to decklink studio , break and not stable .
#20 Posted : Thursday, March 13, 2014 11:22:15 AM(UTC)
Could you report what frame rate and size you have selected for the external output?
Can you also confirm if setting the audio delay in external output to 40 solves the problem?
Guest (10)
3 Pages123>
