Joined: 1/13/2010(UTC) Posts: 5,372  Location: Gold Coast, Australia Was thanked: 4798 time(s) in 1647 post(s)
Joined: 11/12/2012(UTC) Posts: 58  Location: Tarnów, Poland Thanks: 22 times Was thanked: 4 time(s) in 4 post(s)
is it normal that vMix doesn't display "vMix Audio"?  recording and streaming works as normal...
Can you try installing again? It should definitely be there and also set as the default. Is it possible you have it unticked when editing the capture names? It will need to be ticked otherwise when you click OK in settings, it will switch to None and no audio will be recorded.
Joined: 10/30/2013(UTC) Posts: 290 Location: The Netherlands
Thanks: 6 times Was thanked: 21 time(s) in 15 post(s)
What is recommended: Uninstalling the current version or just install vMix12 over the old version?
ok, my fault - "vMix Audio" was unchecked :P (but recording worked normally...)
Joined: 6/29/2011(UTC) Posts: 316   Location: Florida Thanks: 6 times Was thanked: 35 time(s) in 34 post(s)
Bug report, After importing files in to "Photo" module then selecting transition setting the slideshow starts to play in a loop immediately and will not stop.
Hi Ed,
That's correct, the transition dropdown selects the time for it to automatically move through each item in the list.
Martin vMix
Joined: 2/26/2014(UTC) Posts: 83  Location: Canada Thanks: 18 times Was thanked: 16 time(s) in 16 post(s)
Hi what are requirements to get Hardware Acceleration to MP4 Recording, i try but no cpu difference,i have GTX 660 2 GB Thanks!
admin wrote:Hi Ed,
Martin vMix Hey Martin, I thought after selecting the transition time the module would wait to be triggered start either by manually clicking the play button or in the options setting that quick plays items when sent to program out.
A small update has been released to vMix 12 (12.0.0.112)Fixes: * OverlayInputIn shortcut would not activate if Overlay was already in use by another input. * OverlayInput shortcuts would not work if Overlay was currently being previewed. * Default Audio Delay option added to Settings - Audio to allow fine tuning when using external mixer. See: http://www.vmix.com.au/help12/RecordingAudio.html* Audio Delay allows negative values for video clips * Audio Delays up to 20 seconds can now be set This update can found on the web site Download page.
Hi Martin. I was looking Vmix 12 Trial, i used with blackmagic Intensity Pro with last driver of the card, and it has problem with audio, Audio go out break, i tested with Vmix 11 and its fine. Sorry for the english. Thank you.
Could you describe in a bit more detail the audio issue? Perhaps check the correct Recording audio device is selected in vMix Settings -> Audio. It should be vMix Audio by default.
Recording works fine, i have selected Vmix audio, but the audio that go out its bad, works fine about 1 hour and starts to break. Vmix audio out i set decklink audio and external out i set decklink audio and the same thing. I have 2 card 1 for input 1 for output, and audio input from card its brake.
So audio in the recording is fine, just not on the external output? I am a bit confused by this "Vmix audio out i set decklink audio" as you should only be setting decklink audio in the external output settings.
Audio recording its fine, only in external output its works bad, with Vmix 11 works fine both. I set Audio output direct sound and its the same, in external go break audio.
Can work Vmix with matrox rtx2?
What does the audio sound like? Can you list all of the settings you are using in External Output? Try setting a small audio delay in External Output settings such as 40
Audio output: decklink audio Recording Audio: Vmix Audio External output device: Decklink Audio device: decklink audio
Thanks: 3 times Was thanked: 11 time(s) in 9 post(s)
Confirmed , vmix 12 external audio output to decklink studio , break and not stable .
Could you report what frame rate and size you have selected for the external output? Can you also confirm if setting the audio delay in external output to 40 solves the problem?
