HI, I can't seem to activate Bus C on my audio in Vmix. I've set the output of the bus to a virtual cable, but although it is on the 'outputs' it is not shown on the 'inputs'. Can anyone help? Thanks.
Originally Posted by: Studiorove  HI, I can't seem to activate Bus C on my audio in Vmix. I've set the output of the bus to a virtual cable, but although it is on the 'outputs' it is not shown on the 'inputs'. Can anyone help? Thanks.
I believe only Master("M"), Bus A ("A"), and Bus B ("B") have their own discreet send icons in the Audio Mixer, you have to right click on the input to assign a send to Bus C and later.
@ Studiorove
Right click the [M][A][B] buttons of the Input and it opens a pop-up window with additional enabled Buses C-G
Thanks Guys. I could not find that anywhere, I eventually figured it out after a lot of 'clicking'. I needed the extra bus to use Zoom for somebody who can't use the Vmix call because of firewall issues.
