When audio is inactive, it bounces as blue, when active, green.
Would it be possible for the user to have preset colours, so that each audio bus, would bounce as a different colour? That way when viewing inputs it's easy to identify if the audio bouncing is going through the master feed or else where.
Example
If Master and any other bus is active stay green. If Bus A - Yellow If Bus B - Orange
and so forth.
However i think it may be important to have these settings be enabled/disabled but not necessarily customized so any vmix system would retain the same settings.
