	vMix Call
	vMix call video quality
                Greetings,
  We are having issues with the video quality being poor, but we do not appear to be dropping frames.  The video/audio is not choppy, just poor quality video resolution.
  What should we be looking at to troubleshoot?
  Thanks,
 Joined: 9/9/2020(UTC) Posts: 97  Location: Noord-Brabant Thanks: 3 times Was thanked: 13 time(s) in 12 post(s)
                Do a speedtest on all locations. Most providers offer good downstream but bad upstream.
  Check the performance of your firewall/router.
  Try to disable realtime virus scanning.
  Check system I/O to disk.
                Hi Pepsi,
  That was the first thing we did and there is tons of upload capacity.
  At our studio we are using a Cisco asr1001X router with tons of pipe on a fiber circuit.  We can see the UDP stream coming in at about 1.4Mbps for each caller.
                Have you disabled the antivirus on both ends?
                Yes.  PCs are super clean.  Is 1.4Mbps sound right for the UDP traffic inbound to our studio (per vMix call)
                1.4 sounds what i’ve seen. But it is still WebRTC traffic. I prefer MS Teams with NDI.  I had a beter quality experience with that, than vmix call.
  I use vmixcall as backup.
  Is evrything wired? Or a part wireless? Is QOS enabled?
                I'm not sure.
  What is the new URL and what is the old URL?
  I saw your link.  We are not using the beta.  We are using vmixcall.com
                I had better expirience on the beta.
  For vmix call the cpu performance is important. Olf i7 (5 years) runs better with vmixcall on a brand new i5.
  I run my vmix host system on an i9 9th gen with 2 ssd in a raid 0 setup. I still prefer teams
 Joined: 7/28/2019(UTC) Posts: 351  Location: Santa Rosa Thanks: 1 times Was thanked: 53 time(s) in 51 post(s)
                I have yet to try Teams. How did you solve the audio being brought on all channels. Do you have someone mute on the Teams side?
  Did you find a way to talk back without going to active speakers?
 Joined: 5/10/2020(UTC) Posts: 104   Location: Sacramento, California Thanks: 13 times Was thanked: 5 time(s) in 5 post(s)
                A thing I've been experiencing lately is only getting 300-400 Kbps even though the guest's speed test shows plenty of upload bandwidth (10+ Mbps).  Per Martin's suggestion, I've been forcing the guest's bandwidth and it has cleared up the signals in most cases.  I find 2000 Kbps to be an adequate bitrate for a 720p webcam.
	vMix Call
