dbauman
#1 Posted : Tuesday, October 20, 2020 7:00:11 AM(UTC)
dbauman
Greetings,
We are having issues with the video quality being poor, but we do not appear to be dropping frames. The video/audio is not choppy, just poor quality video resolution.
What should we be looking at to troubleshoot?
Thanks,
Pepsi(~)
#2 Posted : Tuesday, October 20, 2020 7:17:40 AM(UTC)
Pepsi(~)
Netherlands
Do a speedtest on all locations.
Most providers offer good downstream but bad upstream.
Check the performance of your firewall/router.
Try to disable realtime virus scanning.
Check system I/O to disk.
dbauman
#3 Posted : Tuesday, October 20, 2020 7:20:04 AM(UTC)
dbauman
Hi Pepsi,
That was the first thing we did and there is tons of upload capacity.
At our studio we are using a Cisco asr1001X router with tons of pipe on a fiber circuit. We can see the UDP stream coming in at about 1.4Mbps for each caller.
Pepsi(~)
#4 Posted : Tuesday, October 20, 2020 7:22:19 AM(UTC)
Pepsi(~)
Netherlands
Have you disabled the antivirus on both ends?
dbauman
#5 Posted : Tuesday, October 20, 2020 7:23:46 AM(UTC)
dbauman
Yes. PCs are super clean. Is 1.4Mbps sound right for the UDP traffic inbound to our studio (per vMix call)
Pepsi(~)
#6 Posted : Tuesday, October 20, 2020 7:29:18 AM(UTC)
Pepsi(~)
Netherlands
1.4 sounds what i’ve seen. But it is still WebRTC traffic. I prefer MS Teams with NDI.
I had a beter quality experience with that, than vmix call.
I use vmixcall as backup.
Is evrything wired? Or a part wireless? Is QOS enabled?
Pepsi(~)
#7 Posted : Tuesday, October 20, 2020 7:31:08 AM(UTC)
Pepsi(~)
Netherlands
Are you using the new url? Or the old?
https://forums.vmix.com/...-vMix-Call-Web-Site-Beta
dbauman
#8 Posted : Tuesday, October 20, 2020 7:32:44 AM(UTC)
dbauman
I'm not sure.
What is the new URL and what is the old URL?
I saw your link. We are not using the beta. We are using vmixcall.com
Pepsi(~)
#9 Posted : Tuesday, October 20, 2020 7:54:38 AM(UTC)
Pepsi(~)
Netherlands
I had better expirience on the beta.
For vmix call the cpu performance is important.
Olf i7 (5 years) runs better with vmixcall on a brand new i5.
I run my vmix host system on an i9 9th gen with 2 ssd in a raid 0 setup. I still prefer teams
Vince Beck
#10 Posted : Tuesday, October 20, 2020 11:01:45 AM(UTC)
Vince Beck
I have yet to try Teams. How did you solve the audio being brought on all channels. Do you have someone mute on the Teams side?
Did you find a way to talk back without going to active speakers?
Geoff B
#11 Posted : Tuesday, October 20, 2020 3:23:43 PM(UTC)
Geoff B
A thing I've been experiencing lately is only getting 300-400 Kbps even though the guest's speed test shows plenty of upload bandwidth (10+ Mbps). Per Martin's suggestion, I've been forcing the guest's bandwidth and it has cleared up the signals in most cases. I find 2000 Kbps to be an adequate bitrate for a 720p webcam.
Guest (5)
