How do Audio Outputs work? Need to send custom mix out
Joined: 7/10/2020(UTC) Posts: 27  Location: Los Angeles CA Was thanked: 4 time(s) in 3 post(s)
When I open the Audio Outputs menu I normally simply 'enable' the buses. In this case, however, I need to send a specific mix OUT separate from my Master/Headphones mixes. I had thought this could be done by setting, for example, the A Bus from 'enabled' to a specific audio device instead (ie my XLR Sound Card), and then mix whatever I need in the Audio Mixer to Bus A. However, when I make this change, Bus A disappears completely from the Audio Mixer and I am not able to route anything to it.
What am I doing wrong? I have the latest version of vMix - 23.0.0.65, running on Windows 10 x64 w/ i9 and RTX 2070
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
Make sure that your audio device is powered up and connected before you start vMix.
