SeanEmer
#1 Posted : Sunday, October 18, 2020 6:47:32 AM(UTC)
SeanEmer
When I open the Audio Outputs menu I normally simply 'enable' the buses. In this case, however, I need to send a specific mix OUT separate from my Master/Headphones mixes. I had thought this could be done by setting, for example, the A Bus from 'enabled' to a specific audio device instead (ie my XLR Sound Card), and then mix whatever I need in the Audio Mixer to Bus A. However, when I make this change, Bus A disappears completely from the Audio Mixer and I am not able to route anything to it.
What am I doing wrong? I have the latest version of vMix - 23.0.0.65, running on Windows 10 x64 w/ i9 and RTX 2070
dmwkr
#2 Posted : Tuesday, October 20, 2020 4:44:36 AM(UTC)
dmwkr
Make sure that your audio device is powered up and connected before you start vMix.
