66 Pages«<4950515253>»
JAIRODJ
#1001 Posted : Friday, October 16, 2020 8:31:19 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
SetImage does not work.
Hi @elgarf, by chance I was testing the SetImage function, and it does not work in the latest versions of UTC, but I found where it was ... let's say the fault ... looking in the functions file, SetImage section, I found that when removing the added texts " InputImage / Index / "in ELEMENT [InputImage / Index / {1}] ..in StatePatch and ActivewStatePatch, already worked. I do not know if this was the problem .. I am not an expert on the subject .. just look in the functions of a past version that if it worked and check the functions and in this one I did not have these texts.
elgarf
#1002 Posted : Friday, October 16, 2020 3:08:34 PM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@JAIRODJ, I'll fix this. Looks like this happening only for default images =( but I'm not sure.
@chococrispis35, are you sure you really need that?
amir29918
#1003 Posted : Saturday, October 17, 2020 7:43:10 PM(UTC)
amir29918
Iran (Islamic Republic Of)
Hi @elgarf
If we need to customize a score points for Wrestling or other sports (1,2,4)
How can I do that?
elgarf
#1004 Posted : Saturday, October 17, 2020 7:47:09 PM(UTC)
elgarf
Russian Federation
Hi, @amir29918, right now you can create custom button with SetText +=4, +=2.
I can also add wrestling style to Score widget a bit later.
thanks 1 user thanked elgarf for this useful post.
amir29918 on 10/17/2020(UTC)
amir29918
#1005 Posted : Saturday, October 17, 2020 8:57:53 PM(UTC)
amir29918
I think if you added a custom field on style and the button scores editable , it's very good..
kevev
#1006 Posted : Sunday, October 18, 2020 5:58:46 AM(UTC)
kevev
Was thanked: 9 time(s) in 5 post(s)
I noticed that on the new 10-14 version, the status dot is not changing when button is pressed. It works on older versions.
Found out setimagenative is not in the newer versions. I set it to setimage and all is good now. :)
chococrispis35
#1007 Posted : Sunday, October 18, 2020 6:28:56 AM(UTC)
chococrispis35
Elgarf:
I only made reference to the cropping of the monitor because sometimes you need to check that the title does not have any spelling errors.
no problem, it was just a suggestion.
One question: how can I activate or run an external program, for example Excel from a button in u.t.c
I am very grateful for the work you have invested in UTC, and how it helps us control and do unthinkable things in vmix
Thank you!
Chircanu
#1008 Posted : Sunday, October 18, 2020 3:32:18 PM(UTC)
Chircanu
hello to all, @@ Chococrispis35 the problem you have reported might solve. You can make an NDI Monitor widget with output2 preview source from Vmix. For every item in the graphics you want to check, you make a preview button. It's just an opinion of mine
elgarf
#1009 Posted : Sunday, October 18, 2020 3:50:24 PM(UTC)
elgarf
Russian Federation
@chococrisps35, I can make command for executing windows process (it's already exists, but not available for users).
@amir29918, I'll think about it. If custom style will be available, other styles became useless 🤔
@kevev, SetImageNative was mistake)
You meant that status led changing a bit later after clicking or not changing at all?
thanks 2 users thanked elgarf for this useful post.
amir29918 on 10/18/2020(UTC), chococrispis35 on 10/31/2020(UTC)
kevev
#1010 Posted : Sunday, October 18, 2020 4:00:26 PM(UTC)
kevev
I meant the led never changed. But once I changed to using setimage the led is now changing as expected. So all is good now.
elgarf
#1011 Posted : Tuesday, October 20, 2020 2:08:09 PM(UTC)
elgarf
Russian Federation
@amir29918, I've added custom style and +4, +10 buttons also. But I can't add +N button (it made score widget a bit complex, I think. And you also can make your custom button with Button widget).
amir29918 on 10/20/2020(UTC)
Chircanu
#1012 Posted : Friday, October 23, 2020 12:43:51 AM(UTC)
Chircanu
greetings to all, @elgarf, I present to you a situation that I faced at the last match. All good and beautiful until the moment the laptop connected to another wireless network other than the one it was connected to at the time of starting Vmix+UTC. After switching to the new network, the controller resynchronized with Vmix, except NDI Monitor.To function again NDI Monitor must be restartedVmix, which during a transmission is not really possible
What would be the cause and what should I do so that, in the future, I don't have to run into this?
elgarf
#1013 Posted : Friday, October 23, 2020 12:30:08 PM(UTC)
elgarf
Russian Federation
@Chircanu, honestly, I don't know how NDI discover sources internally and what happening when network changes =( that all handled by NDI library.
Are you was able to discover NDI sources in another software? From NDI tools monitor, for example? I can add "Reset" button to NDI monitor module in theory if this is problem in NDI monitor.
Chircanu on 10/24/2020(UTC)
ask
#1014 Posted : Friday, October 23, 2020 2:36:29 PM(UTC)
ask
This is expected behaviour.NDI uses mDNS to discover sources. If you change the network it has to re-scan to find the sources. This can take time. It makes sense that you observed the behaviour above as the source will now have a new IP address. Therefore you will need to re-add the source as an input. In vMix this can be done by using the Change function on the input after the new source has been advertised and recognised. With NDI Monitor, close and reopen will force the discovery.
fekir08
#1015 Posted : Monday, November 2, 2020 8:19:28 PM(UTC)
fekir08
Spain
Hi, I would like to know if it is possible to configure the timer with milliseconds ?
I set the timer with: mm\:ss\:fff
But the results are not as expected
Thank You
elgarf
#1016 Posted : Monday, November 2, 2020 10:45:28 PM(UTC)
elgarf
Russian Federation
Not sure that sending something every millisecond over lan is good idea)
So timer is programmed for minimum seconds.
amir29918 on 11/9/2020(UTC)
jasminlord
#1017 Posted : Monday, November 9, 2020 10:34:26 AM(UTC)
jasminlord
Hi Guys
I'm find UTC and it's just incredible. I try to setup condition to my button but i don't understand how condition are working.
Can someone can explain to me please.
Exemple:
I use overlay 3 to pull out a my score bar. I use overlay 2 to pull out a timer.
But i want to bloc overlay 2 appear if overlay 3 is not on.
Please i need help :)
elgarf
#1018 Posted : Monday, November 9, 2020 4:24:55 PM(UTC)
elgarf
Russian Federation
@jasminlord,
I made small example, you can copy it into Code tab and edit into Constructor. Here I used xpath function to check what value is in overlay 3.
Code:
>Condition(, , xpath('vmix/overlays/overlay[@number="3"]'), !=, '')
	>*OverlayInputX(, 2)
>ConditionEnd()
Dont't forget check "State Dependent" tick.
jasminlord on 11/10/2020(UTC)
amir29918
#1019 Posted : Monday, November 9, 2020 9:04:19 PM(UTC)
amir29918
Hi @elgarf
in my scoreboard I have the timer(24 seconds) . I want to do this action : if the timer under 5 second visible one of the images...
and esle Invisible that image.
How can I do that?
elgarf
#1020 Posted : Monday, November 9, 2020 10:42:55 PM(UTC)
elgarf
Russian Federation
@amir, is this just a number of seconds or something with colons, like mm:ss?
Guest (4)
