Joined: 9/1/2015(UTC) Posts: 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
SetImage does not work. Hi @elgarf, by chance I was testing the SetImage function, and it does not work in the latest versions of UTC, but I found where it was ... let's say the fault ... looking in the functions file, SetImage section, I found that when removing the added texts " InputImage / Index / "in ELEMENT [InputImage / Index / {1}] ..in StatePatch and ActivewStatePatch, already worked. I do not know if this was the problem .. I am not an expert on the subject .. just look in the functions of a past version that if it worked and check the functions and in this one I did not have these texts.
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
@JAIRODJ, I'll fix this. Looks like this happening only for default images =( but I'm not sure.
@chococrispis35, are you sure you really need that?
Hi @elgarf If we need to customize a score points for Wrestling or other sports (1,2,4) How can I do that?
Hi, @amir29918, right now you can create custom button with SetText +=4, +=2. I can also add wrestling style to Score widget a bit later.
 1 user thanked elgarf for this useful post.
Originally Posted by: elgarf  Hi, @amir29918, right now you can create custom button with SetText +=4, +=2. I can also add wrestling style to Score widget a bit later. I think if you added a custom field on style and the button scores editable , it's very good..  Capture.PNG (31kb) downloaded 6 time(s).
Thanks: 6 times Was thanked: 9 time(s) in 5 post(s)
I noticed that on the new 10-14 version, the status dot is not changing when button is pressed. It works on older versions.
Found out setimagenative is not in the newer versions. I set it to setimage and all is good now. :)
Thanks: 2 times Was thanked: 7 time(s) in 6 post(s)
Elgarf:
I only made reference to the cropping of the monitor because sometimes you need to check that the title does not have any spelling errors.
no problem, it was just a suggestion.
One question: how can I activate or run an external program, for example Excel from a button in u.t.c
I am very grateful for the work you have invested in UTC, and how it helps us control and do unthinkable things in vmix Thank you!
Thanks: 75 times Was thanked: 7 time(s) in 7 post(s)
hello to all, @@ Chococrispis35 the problem you have reported might solve. You can make an NDI Monitor widget with output2 preview source from Vmix. For every item in the graphics you want to check, you make a preview button. It's just an opinion of mine
@chococrisps35, I can make command for executing windows process (it's already exists, but not available for users). @amir29918, I'll think about it. If custom style will be available, other styles became useless 🤔 @kevev, SetImageNative was mistake) You meant that status led changing a bit later after clicking or not changing at all?
 2 users thanked elgarf for this useful post.
Originally Posted by: elgarf  @chococrisps35, I can make command for executing windows process (it's already exists, but not available for users). @amir29918, I'll think about it. If custom style will be available, other styles became useless 🤔 @kevev, SetImageNative was mistake) You meant that status led changing a bit later after clicking or not changing at all? I meant the led never changed. But once I changed to using setimage the led is now changing as expected. So all is good now.
@amir29918, I've added custom style and +4, +10 buttons also. But I can't add +N button (it made score widget a bit complex, I think. And you also can make your custom button with Button widget).
greetings to all, @elgarf, I present to you a situation that I faced at the last match. All good and beautiful until the moment the laptop connected to another wireless network other than the one it was connected to at the time of starting Vmix+UTC. After switching to the new network, the controller resynchronized with Vmix, except NDI Monitor.To function again NDI Monitor must be restartedVmix, which during a transmission is not really possible What would be the cause and what should I do so that, in the future, I don't have to run into this?
@Chircanu, honestly, I don't know how NDI discover sources internally and what happening when network changes =( that all handled by NDI library.
Are you was able to discover NDI sources in another software? From NDI tools monitor, for example? I can add "Reset" button to NDI monitor module in theory if this is problem in NDI monitor.
Originally Posted by: Chircanu  greetings to all, @elgarf, I present to you a situation that I faced at the last match. All good and beautiful until the moment the laptop connected to another wireless network other than the one it was connected to at the time of starting Vmix+UTC. After switching to the new network, the controller resynchronized with Vmix, except NDI Monitor.To function again NDI Monitor must be restartedVmix, which during a transmission is not really possible What would be the cause and what should I do so that, in the future, I don't have to run into this? This is expected behaviour.NDI uses mDNS to discover sources. If you change the network it has to re-scan to find the sources. This can take time. It makes sense that you observed the behaviour above as the source will now have a new IP address. Therefore you will need to re-add the source as an input. In vMix this can be done by using the Change function on the input after the new source has been advertised and recognised. With NDI Monitor, close and reopen will force the discovery.
 1 user thanked ask for this useful post.
Hi, I would like to know if it is possible to configure the timer with milliseconds ?
I set the timer with: mm\:ss\:fff
But the results are not as expected
Thank You
Not sure that sending something every millisecond over lan is good idea)
So timer is programmed for minimum seconds.
Hi Guys
I'm find UTC and it's just incredible. I try to setup condition to my button but i don't understand how condition are working. Can someone can explain to me please.
Exemple: I use overlay 3 to pull out a my score bar. I use overlay 2 to pull out a timer. But i want to bloc overlay 2 appear if overlay 3 is not on.
Please i need help :)
@jasminlord, I made small example, you can copy it into Code tab and edit into Constructor. Here I used xpath function to check what value is in overlay 3. Code:>Condition(, , xpath('vmix/overlays/overlay[@number="3"]'), !=, '')
>*OverlayInputX(, 2)
>ConditionEnd()
Dont't forget check "State Dependent" tick.
Hi @elgarf in my scoreboard I have the timer(24 seconds) . I want to do this action : if the timer under 5 second visible one of the images... and esle Invisible that image. How can I do that?
@amir, is this just a number of seconds or something with colons, like mm:ss?
