vMix 24 Early Preview Released!
Joined: 7/19/2017(UTC) Posts: 45  Thanks: 11 times Was thanked: 14 time(s) in 7 post(s)
EDIT: Didn't read. Cropping border issue was covered.
Is the 8 camera instant replay only available for the pro edition. I have 4k and can only get 1 camera to load. It gives me the options on the replay configuration to load a camera on 1 and a camera on 8 but only 1 works.
Joined: 1/13/2010(UTC) Posts: 5,338  Location: Gold Coast, Australia Was thanked: 4740 time(s) in 1626 post(s)
Originally Posted by: NewsworthyVision  EDIT: Didn't read. Cropping border issue was covered. We are working on adding support for this, as it does seem to be an important feature to have!
Joined: 11/9/2018(UTC) Posts: 57  Location: Vårgårda Thanks: 21 times Was thanked: 2 time(s) in 1 post(s)
Edit:
Now I found out that if I just install with the exe-file I lose the scripts. But if I install with old vMix still running,(same as you do with upgrade)then I still have the scripts there. ! ! !
I don´t know if it´s covered somevere else.
Scripts are lost when you install new version 24 Preview
You have to export all scripts before installation or all of them are lost.
I´m new on scripting so I asume all you used to make scripting already are aware of this.
Joined: 2/16/2017(UTC) Posts: 125   Thanks: 25 times Was thanked: 25 time(s) in 18 post(s)
I still have all my scripts. Did you open the right preset?
Edit:
Remark: You lose Datasources when you make a Preset as new-preset. But you still have your Datasources when you use an old preset and just delete inputs you don´t need. ! ! !
Interesting it works for you but not for me.
Yes I opend same Preset and others as well and Installed vMix 23 as well so I shall investigate more what can be the reason for this. Everything else is there Datasources and all other settings.
Thanks: 64 times Was thanked: 159 time(s) in 143 post(s)
I think scripts are not saved in the preset, but in the general settings. If you haven't updated your vMix 23 install, it probably won't use your general settings.
 1 user thanked dmwkr for this useful post.
Thanks: 11 times Was thanked: 7 time(s) in 4 post(s)
The Instant Replay recordings the audio information seems to be 25 Fps even when the video is recorded 30, is that normal for these files?
Originally Posted by: jvphobic  What is the approximate size comparisons in the old IR codec vs the Vmix codec? I want to get a general idea of HDD size I should be prepping for.
Thanks. Just an easy approximate way of thinking about it, is you should get about per camera.. 3 mins per GB on Low Quality (48Mbps) 2 mins on Standard Quality (72Mbps) 1 min on High Quality (144Mbps) .. approx of course, but its just easy to rem this way.
Joined: 5/7/2012(UTC) Posts: 185  Location: Bucharest Thanks: 48 times Was thanked: 13 time(s) in 11 post(s)
Originally Posted by: admin  Dynamic Inputs and Dynamic Values supported. Whatever is set with these functions can be recalled by typing in "DynamicValue1-4" as the Value field, or selecting the Dynamic options in the Input dropdown.
How we set and re-set the Dynamic Inputs and Dynamic Values for further use? Didn't find anything related in the "Shortcut Function Reference".
Had an error when changing Instant Replay speed while playing.  speed.png (85kb) downloaded 3 time(s).
Joined: 9/1/2015(UTC) Posts: 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
Hi, I would like to suggest something that would help a lot with the subject of titles. I've seen that stinger transitions using GT graphics now use GT's own animations for entry and exit. Taking into account this new feature, perhaps you could implement this same option in the multiview layers of each input, that is, when activating a multiview that contains a GT, it is activated using its input animation and when deactivating its output animation, this would help. a way to increase a kind of overlay at the level of each input, freeing the overlay for more important and more general graphics at the production level. Obviously that would be an extra feature that can be activated or deactivated in each multiview layer, since some users will only want to create compositions without In / OUT animations.
Another situation is having to deal with the titles, it is quite complex not being able to manage the graphics in a better way. If there was a way to create GT LIST, to choose the graph to use without adding a GT in an entry. It would take up less space on the screen.
Thanks for listening.
Hey Martin!
Just had an app crash when closing vmix 24 down. Vmix locked up and had to be forced closed. Ive looked in the event log for details on the app crash but doesn't show much to share with you. Do you want us to share these issues with you??? If so is there an app crash log within vmix?
Steve
In order to diagnose an issue like that, we would need to know the minimal setup in vMix needed to trigger it consistently. If you are able to work this out let us know.
Joined: 6/23/2016(UTC) Posts: 106 Location: Milwaukee
Thanks: 1 times Was thanked: 11 time(s) in 10 post(s)
Ok. Trying to figure this out. Not sure if I am able to do this with Instant Replay.
I would like to record Commentators on a different channel than field audio. Right now everything is on Master when I export in AVI or MP4. But I can't seem to get anything to show up on the other channels. Can anyone point me in the correct direction on that?
EDIT: I am an idiot. I need to breathe and check everything before posting in this channel. Apologies. Disregard.
Well done! Really looking forward to independent output channels for the replay.
I recently purchased a license, once the testing has been complete will I just be able to update? If so, great!
Think I might have to install and have a play around :)
Joined: 10/22/2020(UTC) Posts: 3  Location: Illinois Thanks: 1 times
Excited to see that border support is being added, however, +1 for ability to follow the cropped sizing of the layer. It is fairly rare comparatively that I am using a full 16:9 frame in a multi view when I want to use borders. Really hope this feature can be updated to support this before final release.
vMix 24.0.0.36 beta releasedhttps://cdn.vmix.com/download/vmix24preview.exe* YouTube Stream Now brought back to life! Kind of...we have implemented an automated system to create events to replicate the old Stream Now functionality that was discontinued by YouTube. Select YouTube Stream Now as destination and login using YouTube Settings button. Can also select previously created events on the YouTube web site. * Input Layer borders now support cropping! * New built in GT Stinger transition templates * Stinger overlay settings now defaults to Cut transition on new presets. * New FEIM (NDI Faulty Encoder Isolation Mode) checkbox when adding NDI inputs, so only problem inputs can be added without reducing the performance of others. * Fixed error when changing replay speed to 0% * Shortcuts template graphics was not displaying some shortcuts if count was exactly 13. * Fixed RGB sources in Replay showing upside down * Camera 8 dropdown was showing in 4K, even though only one channel is supported.
 9 users thanked admin for this useful post.
No overlays on outputs 2,3,4. Only overlays 7 and 8 (aka stinger 3 and 4) works.  Screenshot (104).png (32kb) downloaded 2 time(s).
