13 Pages<1234>»
NewsworthyVision
#21 Posted : Friday, October 16, 2020 6:37:35 AM(UTC)
NewsworthyVision
Was thanked: 14 time(s) in 7 post(s)
EDIT: Didn't read. Cropping border issue was covered.
WWLivestream
#22 Posted : Friday, October 16, 2020 10:32:11 AM(UTC)
WWLivestream
Is the 8 camera instant replay only available for the pro edition. I have 4k and can only get 1 camera to load. It gives me the options on the replay configuration to load a camera on 1 and a camera on 8 but only 1 works.
#23 Posted : Friday, October 16, 2020 12:37:13 PM(UTC)
Was thanked: 4740 time(s) in 1626 post(s)
We are working on adding support for this, as it does seem to be an important feature to have!
NewsworthyVision on 10/17/2020(UTC)
Gunnar
#24 Posted : Friday, October 16, 2020 6:27:34 PM(UTC)
Gunnar
Sweden
Edit:
Now I found out that if I just install with the exe-file I lose the scripts.
But if I install with old vMix still running,(same as you do with upgrade)then I still have the scripts there. ! ! !
I don´t know if it´s covered somevere else.
Scripts are lost when you install new version 24 Preview
You have to export all scripts before installation or all of them are lost.
I´m new on scripting so I asume all you used to make scripting already are aware of this.
rudyengels
#25 Posted : Friday, October 16, 2020 8:18:29 PM(UTC)
rudyengels
Was thanked: 25 time(s) in 18 post(s)
I still have all my scripts. Did you open the right preset?
Gunnar
#26 Posted : Friday, October 16, 2020 8:55:18 PM(UTC)
Gunnar
Sweden
Edit:
Remark: You lose Datasources when you make a Preset as new-preset.
But you still have your Datasources when you use an old preset and just delete inputs you don´t need. ! ! !
Interesting it works for you but not for me.
Yes I opend same Preset and others as well and Installed vMix 23 as well so I shall investigate more what can be the reason for this.
Everything else is there Datasources and all other settings.
dmwkr
#27 Posted : Friday, October 16, 2020 9:15:36 PM(UTC)
dmwkr
I think scripts are not saved in the preset, but in the general settings. If you haven't updated your vMix 23 install, it probably won't use your general settings.
thanks 1 user thanked dmwkr for this useful post.
Gunnar on 10/26/2020(UTC)
Quinton
#28 Posted : Saturday, October 17, 2020 11:26:03 PM(UTC)
Quinton
Was thanked: 7 time(s) in 4 post(s)
The Instant Replay recordings the audio information seems to be 25 Fps even when the video is recorded 30, is that normal for these files?
Quinton
#29 Posted : Saturday, October 17, 2020 11:50:52 PM(UTC)
Quinton
Originally Posted by: jvphobic Go to Quoted Post
What is the approximate size comparisons in the old IR codec vs the Vmix codec? I want to get a general idea of HDD size I should be prepping for.
Thanks.
Just an easy approximate way of thinking about it, is you should get about per camera..
3 mins per GB on Low Quality (48Mbps)
2 mins on Standard Quality (72Mbps)
1 min on High Quality (144Mbps) .. approx of course, but its just easy to rem this way.
ClementN
#30 Posted : Sunday, October 18, 2020 4:29:01 AM(UTC)
ClementN
Romania
Originally Posted by: admin Go to Quoted Post
Dynamic Inputs and Dynamic Values supported. Whatever is set with these functions can be recalled by typing in "DynamicValue1-4" as the Value field, or selecting the Dynamic options in the Input dropdown.
How we set and re-set the Dynamic Inputs and Dynamic Values for further use?
Didn't find anything related in the "Shortcut Function Reference".
Quinton
#31 Posted : Monday, October 19, 2020 1:52:34 AM(UTC)
Quinton
Had an error when changing Instant Replay speed while playing. speed.png (85kb) downloaded 3 time(s).
JAIRODJ
#32 Posted : Tuesday, October 20, 2020 2:20:31 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Hi, I would like to suggest something that would help a lot with the subject of titles.
I've seen that stinger transitions using GT graphics now use GT's own animations for entry and exit.
Taking into account this new feature, perhaps you could implement this same option in the multiview layers of each input,
that is, when activating a multiview that contains a GT, it is activated using its input animation and when deactivating its output animation, this would help. a way to increase a kind of overlay at the level of each input, freeing the overlay for more important and more general graphics at the production level.
Obviously that would be an extra feature that can be activated or deactivated in each multiview layer, since some users will only want to create compositions without In / OUT animations.
Another situation is having to deal with the titles, it is quite complex not being able to manage the graphics in a better way. If there was a way to create GT LIST, to choose the graph to use without adding a GT in an entry. It would take up less space on the screen.
Thanks for listening.
stevematthews
#33 Posted : Tuesday, October 20, 2020 7:32:19 AM(UTC)
stevematthews
Hey Martin!
Just had an app crash when closing vmix 24 down. Vmix locked up and had to be forced closed. Ive looked in the event log for details on the app crash but doesn't show much to share with you. Do you want us to share these issues with you??? If so is there an app crash log within vmix?
Steve
#34 Posted : Tuesday, October 20, 2020 1:15:23 PM(UTC)
In order to diagnose an issue like that, we would need to know the minimal setup in vMix needed to trigger it consistently.
If you are able to work this out let us know.
jvphobic
#35 Posted : Wednesday, October 21, 2020 8:21:57 AM(UTC)
jvphobic
Was thanked: 11 time(s) in 10 post(s)
Ok. Trying to figure this out. Not sure if I am able to do this with Instant Replay.
I would like to record Commentators on a different channel than field audio. Right now everything is on Master when I export in AVI or MP4. But I can't seem to get anything to show up on the other channels. Can anyone point me in the correct direction on that?
NewsworthyVision
#36 Posted : Wednesday, October 21, 2020 8:30:35 PM(UTC)
NewsworthyVision
EDIT: I am an idiot. I need to breathe and check everything before posting in this channel. Apologies. Disregard.
tomtailford
#37 Posted : Thursday, October 22, 2020 12:20:29 AM(UTC)
tomtailford
Well done! Really looking forward to independent output channels for the replay.
I recently purchased a license, once the testing has been complete will I just be able to update? If so, great!
Think I might have to install and have a play around :)
tristencrow
#38 Posted : Thursday, October 22, 2020 1:22:42 AM(UTC)
tristencrow
Excited to see that border support is being added, however, +1 for ability to follow the cropped sizing of the layer. It is fairly rare comparatively that I am using a full 16:9 frame in a multi view when I want to use borders. Really hope this feature can be updated to support this before final release.
#39 Posted : Friday, October 23, 2020 3:23:53 PM(UTC)
vMix 24.0.0.36 beta released
https://cdn.vmix.com/download/vmix24preview.exe
* YouTube Stream Now brought back to life!
Kind of...we have implemented an automated system to create events to replicate the old Stream Now functionality that was discontinued by YouTube.
Select YouTube Stream Now as destination and login using YouTube Settings button.
Can also select previously created events on the YouTube web site.
* Input Layer borders now support cropping!
* New built in GT Stinger transition templates
* Stinger overlay settings now defaults to Cut transition on new presets.
* New FEIM (NDI Faulty Encoder Isolation Mode) checkbox when adding NDI inputs, so only problem inputs can be added without reducing the performance of others.
* Fixed error when changing replay speed to 0%
* Shortcuts template graphics was not displaying some shortcuts if count was exactly 13.
* Fixed RGB sources in Replay showing upside down
* Camera 8 dropdown was showing in 4K, even though only one channel is supported.
thanks 9 users thanked admin for this useful post.
doggy on 10/23/2020(UTC), stigaard on 10/23/2020(UTC), rudyengels on 10/23/2020(UTC), Gunnar on 10/23/2020(UTC), sontoloyo on 10/24/2020(UTC), raugert on 10/25/2020(UTC), ask on 10/25/2020(UTC), tristencrow on 11/1/2020(UTC), eduardocfs on 12/10/2020(UTC)
zntgrg
#40 Posted : Saturday, October 24, 2020 10:47:46 PM(UTC)
zntgrg
Italy
No overlays on outputs 2,3,4. Only overlays 7 and 8 (aka stinger 3 and 4) works.
Screenshot (104).png (32kb) downloaded 2 time(s).
Guest (12)
13 Pages<1234>»
