Thanks: 2 times Was thanked: 7 time(s) in 6 post(s)
i send to your email, when enable record log crashes utc and close
i replaced with your last version (bug fixes), but crashes
Thanks: 75 times Was thanked: 7 time(s) in 7 post(s)
Hello everyone, @elgarf, I do not know if this happens only to me, but I encounter the following problem: I do not load a previous save until I delete the log file from my documents, and after about 2 hours of operation stops itself. We also found a great addition in operation, consumes quite a little memory, which is sensational. last file deleted had 280mb
Joined: 10/23/2015(UTC) Posts: 458   Thanks: 20 times Was thanked: 231 time(s) in 130 post(s)
@Chircanu, I reduced logging to only errors in the next version, which I'll upload today.
Hope someday I'll fix all bugs =)
 1 user thanked elgarf for this useful post.
Hello everyone, I look forward to the new update and it was fully worth it. Everything seems to work perfectly (the functions that I use, there are many that I do not master). However, a small problem I found: no longer works NDI Monitor (connects, displays available sources, but does not take the image. I hope this problem is the last, and @elgarf take a well-deserved break. Once again, I thank you for all your support and the promptness with which you help us every time.
LE: I tried and I made an NDI widget from external data/default/NdiMonitorDataProvider. everything manually. That's how it works
Elgarf
i try the new update, i found a small problem i load my proyect and I have a score widget and added a reset link, I have assigned reset to a button but when resetting it does not put number 0, only see blank space, no number 0 it does not appear, until I add 1 or more numbers the numbers appear, but the number 0 does not, previously it did appear .
The problem is when executing the reset link through a button, it does the reset but does not put the 0, it leaves it empty, but if I reset manually it works
@chococrispis35, I spent hours, solving this problem :D The point is that when you put zero into text field, all works OK, but when you do same thing in score, text in title just set to blank. (funny, that text field and score are the same widget actually).
i found out that in new version clock is to slow... when producing soccer... in 45 min - clock is up to 4 minutes to slow...
i went back to version 06/2020 - here everything fine...
thx again for this great tool!
@wolfmayr, hope, I fix it tomorrow =)
Btw, why many people use Data Providers in UTC instead of vMix Data Sources?
Also in the latest versions there is JSON Data Provider, just in case anybody need it.
Found this problem too time is late Tell me how to make a ndi monitor However, a small problem I found: no longer works NDI Monitor (connects, displays available sources, but does not take the image. Originally Posted by: wolfmayr  i found out that in new version clock is to slow... when producing soccer... in 45 min - clock is up to 4 minutes to slow...
I've changed timer for timer widget to high precision timer. Should work better now.
NDI moitor should be fixed in the latest version. Or you can change load NDI monitor manually by adding Default External Data widget.
Is anybody use scoreboard controllers, etc. I'm interested in how to get info from controller (is it just xml/json/text file) or COM port, etc.?
Originally Posted by: elgarf  Is anybody use scoreboard controllers, etc. I'm interested in how to get info from controller (is it just xml/json/text file) or COM port, etc.? Hello everyone, @elgarf, I have the impression that at the last update(12.10.2020) remained the executable from the verprevious section(08.10.2020) Shows me that there is a new version and must be updated. Although I use the version of 08.10, since the update appeared from 12.10 no longer recognize stare previous projects
Hmm. I'll check this a bit later.
Elgarf
I will send you an email, it is an excel file, how to read from com2 a speed gun, this generates the speed for me, linked to the cg title, using the strokereader-2.6.4.0 program. the gun speed is a Stalker sport 2
 1 user thanked chococrispis35 for this useful post.
I've updated latest version with same link. Sorry, my bad =(
Joined: 9/1/2015(UTC) Posts: 128  Location: Ecuador Thanks: 2 times Was thanked: 16 time(s) in 12 post(s)
Hi @elgarf, could you please help me with the way the WaitForCompletion function is used I can't get it to work properly. Thanks for your help.
Looks like this command doesn' work proper in UTC (web request timeout is 5sec by default, so I make timeout for this command longer). I'll post fix tomorrow.
Elgarf
In the timer widget has a bug, reverse time can be selected in the entire widget box area without having to select the reverse box and that makes reverse automatically be selected or not .
Same in external data, Excel Data on box area "row is table"
Elgarf... Next Challange.... Oppssss jajajajaja
I have a crazy idea: On ndi monitor can I have the option of cropping independent of monitor size (only see the area of interest)? for example only the title area without having the entire screen. the purpose is to preview the titles that are good.
