66 Pages«<4849505152>»
chococrispis35
#981 Posted : Tuesday, October 6, 2020 5:26:18 AM(UTC)
chococrispis35
i send to your email, when enable record log crashes utc and close
chococrispis35
#982 Posted : Tuesday, October 6, 2020 5:50:31 AM(UTC)
chococrispis35
i replaced with your last version (bug fixes), but crashes
Chircanu
#983 Posted : Wednesday, October 7, 2020 4:53:44 AM(UTC)
Chircanu
Hello everyone, @elgarf, I do not know if this happens only to me, but I encounter the following problem: I do not load a previous save until I delete the log file from my documents, and after about 2 hours of operation stops itself. We also found a great addition in operation, consumes quite a little memory, which is sensational. last file deleted had 280mb
elgarf
#984 Posted : Wednesday, October 7, 2020 2:16:29 PM(UTC)
elgarf
Russian Federation
Was thanked: 231 time(s) in 130 post(s)
@Chircanu, I reduced logging to only errors in the next version, which I'll upload today.
Hope someday I'll fix all bugs =)
thanks 1 user thanked elgarf for this useful post.
Chircanu on 10/7/2020(UTC)
Chircanu
#985 Posted : Thursday, October 8, 2020 12:05:45 AM(UTC)
Chircanu
Hello everyone, I look forward to the new update and it was fully worth it. Everything seems to work perfectly (the functions that I use, there are many that I do not master). However, a small problem I found: no longer works NDI Monitor (connects, displays available sources, but does not take the image. I hope this problem is the last, and @elgarf take a well-deserved break. Once again, I thank you for all your support and the promptness with which you help us every time.
LE: I tried and I made an NDI widget from external data/default/NdiMonitorDataProvider. everything manually. That's how it works
chococrispis35
#986 Posted : Thursday, October 8, 2020 1:27:21 AM(UTC)
chococrispis35
Elgarf
i try the new update, i found a small problem
i load my proyect and I have a score widget and added a reset link,
I have assigned reset to a button but when resetting it does not put number 0, only see blank space, no number 0
it does not appear, until I add 1 or more numbers the numbers appear, but the number 0 does not, previously it did appear .
The problem is when executing the reset link through a button, it does the reset but does not put the 0, it leaves it empty, but if I reset manually it works
elgarf
#987 Posted : Thursday, October 8, 2020 1:20:42 PM(UTC)
elgarf
Russian Federation
@chococrispis35, I spent hours, solving this problem :D
The point is that when you put zero into text field, all works OK, but when you do same thing in score, text in title just set to blank. (funny, that text field and score are the same widget actually).
wolfmayr
#988 Posted : Thursday, October 8, 2020 10:01:46 PM(UTC)
wolfmayr
i found out that in new version clock is to slow... when producing soccer... in 45 min - clock is up to 4 minutes to slow...
i went back to version 06/2020 - here everything fine...
thx again for this great tool!
elgarf
#989 Posted: : Thursday, October 8, 2020 11:10:39 PM(UTC)
elgarf
Russian Federation
@wolfmayr, hope, I fix it tomorrow =)
Btw, why many people use Data Providers in UTC instead of vMix Data Sources?
Also in the latest versions there is JSON Data Provider, just in case anybody need it.
coa78495
#990 Posted : Saturday, October 10, 2020 8:34:42 AM(UTC)
coa78495
Russian Federation
Found this problem too
time is late
Tell me how to make a ndi monitor
elgarf
#991 Posted : Monday, October 12, 2020 5:23:08 PM(UTC)
elgarf
Russian Federation
I've changed timer for timer widget to high precision timer. Should work better now.
NDI moitor should be fixed in the latest version. Or you can change load NDI monitor manually by adding Default External Data widget.
elgarf
#992 Posted : Monday, October 12, 2020 6:30:27 PM(UTC)
elgarf
Russian Federation
Is anybody use scoreboard controllers, etc. I'm interested in how to get info from controller (is it just xml/json/text file) or COM port, etc.?
Chircanu
#993 Posted : Monday, October 12, 2020 11:46:43 PM(UTC)
Chircanu
Hello everyone, @elgarf, I have the impression that at the last update(12.10.2020) remained the executable from the verprevious section(08.10.2020) Shows me that there is a new version and must be updated.
Although I use the version of 08.10, since the update appeared from 12.10 no longer recognize stare previous projects
elgarf
#994 Posted : Tuesday, October 13, 2020 12:19:53 AM(UTC)
elgarf
Russian Federation
Hmm. I'll check this a bit later.
chococrispis35
#995 Posted : Tuesday, October 13, 2020 12:50:04 AM(UTC)
chococrispis35
Elgarf
I will send you an email, it is an excel file, how to read from com2 a speed gun, this generates the speed for me, linked to the cg title, using the strokereader-2.6.4.0 program. the gun speed is a Stalker sport 2
thanks 1 user thanked chococrispis35 for this useful post.
elgarf on 10/13/2020(UTC)
elgarf
#996 Posted : Tuesday, October 13, 2020 2:15:17 AM(UTC)
elgarf
Russian Federation
I've updated latest version with same link. Sorry, my bad =(
JAIRODJ
#997 Posted : Tuesday, October 13, 2020 3:39:37 AM(UTC)
JAIRODJ
Was thanked: 16 time(s) in 12 post(s)
Hi @elgarf, could you please help me with the way the WaitForCompletion function is used
I can't get it to work properly.
Thanks for your help.
elgarf
#998 Posted : Tuesday, October 13, 2020 4:05:51 AM(UTC)
elgarf
Russian Federation
Looks like this command doesn' work proper in UTC (web request timeout is 5sec by default, so I make timeout for this command longer). I'll post fix tomorrow.
chococrispis35
#999 Posted : Wednesday, October 14, 2020 1:15:36 AM(UTC)
chococrispis35
Elgarf
In the timer widget has a bug, reverse time can be selected in the entire widget box area without having to select the reverse box and that makes reverse automatically be selected or not .
Same in external data, Excel Data on box area "row is table"
elgarf on 10/14/2020(UTC)
chococrispis35
#1000 Posted : Friday, October 16, 2020 5:35:28 AM(UTC)
chococrispis35
Elgarf... Next Challange.... Oppssss jajajajaja
I have a crazy idea:
On ndi monitor can I have the option of cropping
independent of monitor size (only see the area of ​​interest)?
for example only the title area without having the entire screen.
the purpose is to preview the titles that are good.
Guest (13)
