adavind
#1 Posted : Wednesday, September 16, 2020 6:02:12 PM(UTC)
adavind
I created a simple title using an image sequence and a text box. There are both on one layer.
The image sequence lasts 6 seconds and has 2 animations for the transitionin and transitionout (fade and imagesequence)
The text box has 1 animation for both: fade.
The preview of the transitions work fine in the title editor.
When I add the title as an input and click overlay 1 (Set to cut, 500ms) the animation shows the transitionIn just fine. However, when I click the overlay 1 button again the overlay does the hard cut and does not show the out.
Is this something I need to script or setup as a trigger? I'm not exactly sure how to accomplish this.
Thanks!
#2 Posted : Wednesday, September 16, 2020 6:30:43 PM(UTC)
When the title animations are properly setup there is no need for script or triggers
Did you check by using Play or In/Out?
Would help if you posted a screenshot of the animation list in your title
adavind
#3 Posted : Thursday, September 17, 2020 1:10:14 AM(UTC)
adavind
Screenshot 2020-09-16 080914.png (28kb) downloaded 4 time(s).
