GT
TransitionOut not shown for overlay
I created a simple title using an image sequence and a text box. There are both on one layer.
The image sequence lasts 6 seconds and has 2 animations for the transitionin and transitionout (fade and imagesequence)
The text box has 1 animation for both: fade.
The preview of the transitions work fine in the title editor.
When I add the title as an input and click overlay 1 (Set to cut, 500ms) the animation shows the transitionIn just fine. However, when I click the overlay 1 button again the overlay does the hard cut and does not show the out.
Is this something I need to script or setup as a trigger? I'm not exactly sure how to accomplish this.
Thanks!
Joined: 12/27/2012(UTC) Posts: 5,539  Location: Belgium Thanks: 319 times Was thanked: 1022 time(s) in 839 post(s)
When the title animations are properly setup there is no need for script or triggers Quote:The preview of the transitions work fine in the title editor. Did you check by using Play or In/Out? Would help if you posted a screenshot of the animation list in your title
Originally Posted by: doggy  When the title animations are properly setup there is no need for script or triggers Quote:The preview of the transitions work fine in the title editor. Did you check by using Play or In/Out? Would help if you posted a screenshot of the animation list in your title  Screenshot 2020-09-16 080914.png (28kb) downloaded 4 time(s).
GT
