GT
Data Source CSV import text symbol problems
Thanks: 8 times Was thanked: 3 time(s) in 3 post(s)
Hi all When I import some scripture text is get a "?" symbol  I've managed to locate the problem down to this symbol >> ” << which is different to the one on my keyboard >> " <<Full Example Text 27. even he who comes after me, the strap of whose sandal I am not worthy to untie.” Does anybody have some solutions for this problem?
After some thought I come to the conclusion that its a vMix Bug?
Joined: 12/27/2012(UTC) Posts: 5,523  Location: Belgium Thanks: 318 times Was thanked: 1021 time(s) in 838 post(s)
Originally Posted by: ispyisail  After some thought I come to the conclusion that its a vMix Bug? Yes the bug is in the text source If it is coming from a file saved in ANSI encoding this will be the result , needs to be UTF-8 encoding So not a vMix bug at all
Right so save your files with UTF encoding as your current apparently isn't
Can easily test it with notepad or alike ( gives you the option to save as ANSI or UTF-8)
Thanks for the tips I'll work more on this latter
In getting the text from the application "Theword" then using "Autohotkey" to format and save the text for vMix import
I suspect Autohotkey is not saving in the correct format
again. thanks for the tips
@doggy That fixed the problem 100% Thanks AutoHotkey code Code:^P::
FileDelete,C:\Users\Public\Documents\clip.csv
Fileappend,%clipboard%,C:\Users\Public\Documents\clip.csv, UTF-8
return
Just had to add "UTF-8"
GT
