ispyisail
#1 Posted : Monday, September 7, 2020 6:50:28 PM(UTC)
ispyisail
Hi all
When I import some scripture text is get a "?" symbol
I've managed to locate the problem down to this symbol >> ” << which is different to the one on my keyboard >> " <<
Full Example Text
27. even he who comes after me, the strap of whose sandal I am not worthy to untie.”
Does anybody have some solutions for this problem?
ispyisail
#2 Posted : Saturday, September 12, 2020 6:14:55 AM(UTC)
ispyisail
After some thought I come to the conclusion that its a vMix Bug?
#3 Posted : Saturday, September 12, 2020 6:45:58 AM(UTC)
Yes the bug is in the text source
If it is coming from a file saved in ANSI encoding this will be the result , needs to be UTF-8 encoding
So not a vMix bug at all
ispyisail
#4 Posted : Sunday, September 13, 2020 7:03:10 PM(UTC)
ispyisail
From the best I can tell the character is UTF-8
http://www.ltg.ed.ac.uk/...=%E2%80%9D&mode=char
#5 Posted : Sunday, September 13, 2020 7:20:51 PM(UTC)
Right so save your files with UTF encoding as your current apparently isn't
Can easily test it with notepad or alike ( gives you the option to save as ANSI or UTF-8)
ispyisail
#6 Posted : Sunday, September 13, 2020 7:53:46 PM(UTC)
ispyisail
Thanks for the tips
I'll work more on this latter
ispyisail
#7 Posted : Sunday, September 13, 2020 7:58:06 PM(UTC)
ispyisail
In getting the text from the application "Theword" then using "Autohotkey" to format and save the text for vMix import
I suspect Autohotkey is not saving in the correct format
again. thanks for the tips
#8 Posted : Sunday, September 13, 2020 8:06:07 PM(UTC)
ispyisail
#9 Posted : Wednesday, September 16, 2020 6:29:59 PM(UTC)
ispyisail
@doggy
That fixed the problem 100%
AutoHotkey code
Code:
^P::
FileDelete,C:\Users\Public\Documents\clip.csv
Fileappend,%clipboard%,C:\Users\Public\Documents\clip.csv, UTF-8
return
Just had to add "UTF-8"
