NDI
NDI Black Frames on vMix
Its the direct download from the PTZO folks.
Joined: 3/20/2020(UTC) Posts: 32  Location: Oregon Thanks: 1 times Was thanked: 4 time(s) in 4 post(s)
I've had two ~20min and one 1hr livestreams with this version of the NDI tools linked in the PTZ Optics help article and no black frames. I wish Newtek would change the driver version in the installer to reflect the change. It still says v1.0. I haven't seen the artifact problem indicated in the screenshot. If I do I'll report. I'm going to upgrade my cameras back to the current firmware in the next couple days and hopefully the problem is still gone.
Thanks for the reply!
I am updating tomorrow i will post here the results.
Rank: Guest
Groups: Joined: 1/13/2010(UTC) Posts: 230
I have installed that update for couple of days now. What I observed: - at 20000 kbps I have that glitches posted above - at 12000 kbps (NDI high) I didn’t see any glitches until now - my cameras are not in sync from the beginning. They will sync up later by themselves.
Do you know how can sync them?
Mikesg, what’s your bitrate? About the driver version, I wish that too, is still 1.0 :(
Looks like the new NDI tools fixed the issue.
I'm having the exact same problem. My 3 PTZOptics NDI cameras work fine with OBS. I'm trying to switch to vMix and this issue is slowing that process. I will try installing the latest NDI Tools. The workstation is a clean Win10 install and I'm certain I did not install NDI Tools. vMix installation makes no mention of the need to do so and the cameras show up fine as NDI inputs. I'll report back after I install the NDI Tools version PTZOptics suggests.
I updated NDI Tools today and it appears to have cleared the problem. I'll be monitoring it over the next few days to make sure before I commit to using vMix in Sunday's worship service. If th eproblem is not cleared, I'll update this topic.
NDI
