2 Pages<12
kjones9999
#21 Posted : Friday, May 22, 2020 12:04:07 PM(UTC)
kjones9999
Its the direct download from the PTZO folks.
mikesg
#22 Posted : Wednesday, May 27, 2020 3:13:05 PM(UTC)
mikesg
I've had two ~20min and one 1hr livestreams with this version of the NDI tools linked in the PTZ Optics help article and no black frames. I wish Newtek would change the driver version in the installer to reflect the change. It still says v1.0. I haven't seen the artifact problem indicated in the screenshot. If I do I'll report. I'm going to upgrade my cameras back to the current firmware in the next couple days and hopefully the problem is still gone.
kjones9999
#23 Posted : Friday, May 29, 2020 10:33:04 AM(UTC)
kjones9999
Thanks for the reply!
I am updating tomorrow i will post here the results.
Arsene_tiberiu
#24 Posted : Friday, May 29, 2020 3:34:03 PM(UTC)
Rank: Guest
Groups: Guests
I have installed that update for couple of days now. What I observed:
- at 20000 kbps I have that glitches posted above
- at 12000 kbps (NDI high) I didn’t see any glitches until now
- my cameras are not in sync from the beginning. They will sync up later by themselves.
Do you know how can sync them?
Mikesg, what’s your bitrate?
About the driver version, I wish that too, is still 1.0 :(
kjones9999
#25 Posted : Monday, June 1, 2020 11:34:21 AM(UTC)
kjones9999
Looks like the new NDI tools fixed the issue.
pcassidy@cassidys.ca
#26 Posted : Wednesday, September 2, 2020 8:21:25 AM(UTC)
I'm having the exact same problem. My 3 PTZOptics NDI cameras work fine with OBS. I'm trying to switch to vMix and this issue is slowing that process. I will try installing the latest NDI Tools. The workstation is a clean Win10 install and I'm certain I did not install NDI Tools. vMix installation makes no mention of the need to do so and the cameras show up fine as NDI inputs. I'll report back after I install the NDI Tools version PTZOptics suggests.
#27 Posted : Thursday, September 3, 2020 6:59:10 AM(UTC)
I updated NDI Tools today and it appears to have cleared the problem. I'll be monitoring it over the next few days to make sure before I commit to using vMix in Sunday's worship service. If th eproblem is not cleared, I'll update this topic.
Guest (11)
2 Pages<12
